The fourth DAC is a Van Alstine Insight+, actually the same DAC as the one above but with the op-amp upgrade chips. The mid-range thinness is gone, there is even more controlled bass and the final sound compares very favorably to vinyl. Digital now has the same three dimensional soundstage as vinyl.I can happily listen to either format now because there is more difference in the quality of the recordings than which tool I use to play them.Wayne
John,Try this free high definition download.http://www.hdtracks.com/
I love listening to music period. But you are right - Vinyl is kind of special. Mariusz
John,Try this free high definition download.http://www.hdtracks.com/Perhaps you should audition cutting edge digital audio such as the Modwright Transporter, the various offerings by Empirical Audio or a modded Squeezebox and power supply.As you can see here lots of very experienced audiophiles with $$$$ are excited about the Modwright Transporter. I suspect that many of these 'phools have high end vinyl rigs.http://www.audiocircle.com/index.php?topic=56360.0CD players will soon be obsolete.-Roy
