0 Members and 1 Guest are viewing this topic. Read 7421 times.
Would this 1.5T Seagate be what I'm looking for as a simple ( ) internal hard drive switch? If so, how "simple" is "simple"... really?Cheers,Robin
Quote from: satfrat on 26 May 2009, 01:45 amWould this 1.5T Seagate be what I'm looking for as a simple ( ) internal hard drive switch? If so, how "simple" is "simple"... really?Cheers,RobinDepends...is your current HD a SATA drive?If it is, it is as simple as swapping out the old one, installing the new one, running a diagnostic tool to recognize and format the drive, and reboot. You can than copy over your music files from your external drive that you use for backup.George
Robin,Looks good but your first drive listed is a 160GB, so doublecheck what your 2nd 750GB is and then your set.Len
