0 Members and 1 Guest are viewing this topic. Read 79628 times.
Wow, 7 pages allready!I'm still in the middle on this one. I love both for different reasons and I accept both for what they are. I really like to run SS for about a week, then switch to Toob for another week, oscillating back and forth. To be honest, it really seems that the weather affects which amp I listen to. Both of my amps (that I switch back and forth) sound so very close, but the differences are real. The SS has better imaging to a slight degree, while the toob has a slicker midrange, almost buttery. I may have to also say that I might like some classical music on the Toob, but not always, depends on the band. And I usually prefer rock on the SS, but that also depends on who it is.Ya, I know, I'm not much help.Wayner
Screw this SS vs Tube crap..... lets go launch the boat, throw the rod in and get pist.....
QuoteAs Iam not radical, in last case I can accept a SS amp, since it is Class A output, because without alot of heat there is no sound quality.An engineer I respect greatly has said that Class A is a way of getting acceptable performance out of almost any amp design. It covers up a lot of sins.On the other hand, a well-designed Class AB amp will outperform a Class A amp, be vastly more efficient, and be more reliable.
I don't know about that. It seems to me if there are alot of "sins" in the design it would be unreliable by default. Nelson Pass is very well respected among most, I would guess, and I own his Aleph 0s which has performed flawlessly for the 5 years I've owned it (knock on wood). I would assume it's a good design with few, if any, sins.As for performance of A vs. A/B, the Class A SS amps have been the only SS amps that have stayed in my system for any length of time. On paper maybe A/B outperforms A but not to my ears, where I'd say it counts.Can't argue with you about efficiency. But what audiophile cares about efficiency when you've got great sound?
Hey Turkey, that test you mentioned is very interesting! I wonder though if you were actually comparing the mike's ability to record that sound to the natural sound.
Turkey, you are the Yoda of the HTML quote system! I can't seem to figure out how to do it properly! (see above post for evidence)
Can you lower bias on A/B amps without a change in performance/sound? It seems to me, though I'm no expert, that a bias setting is an integral part of the functionality of the amp and changing that would be like removing the spark plug wire on a 12 cylinder Lamborghini and being surprised by a change in performance. I'm guessing amp design (tube and ss) is a very complicated process and trade-offs are inevitable. If it performs well when properly tuned (i.e. running at proper bias) what would lowering the bias prove?
I haven't heard your Aleph amp, but I can say that I have found that NP's commercial designs seem to me to be rather expensive for the performance they give. They're not bad, but they're not better than less expensive amps.
Some Class A amps are evidently mediocre designs that are given an easy fix by biasing them into Class A.That's why I think it would be instructive to bias an amp back down into AB and see what it sounds like.
Are there really folks that prefer solid state sonically?The implication being anything with tubes must sound better than anything without tubes, because most folks prefer tubes. Yeah, tubes are the ticket. I got tubes in my turntable and tonearm. Tubes in my cartridge and cables. Getting tubes put into my telephone and doorbell too. Can't stand listening to anything without tubes. Nearly lost my mind over all this, but while at the hospital they shoved a few tubes up my arse and I'm all better now.Seriously, most people have a mind broad enough to comprehend that tubes, like vinyl can sound like crap. But if you're so naive to believe that the world is black and white, and white is better than black, you've been suckered into a vacuum void of reality... Nevertheless there are some people who will prefer a solid state product that sounds better than something else with tubes that doesn't sound as good.
The implication being anything with tubes must sound better than anything without tubes, because most folks prefer tubes....Seriously, most people have a mind broad enough to comprehend that tubes, like vinyl can sound like crap. But if you're so naive to believe that the world is black and white, and white is better than black, you've been suckered into a vacuum void of reality... Nevertheless there are some people who will prefer a solid state product that sounds better than something else with tubes that doesn't sound as good.
Quote from: Wind Chaser on 10 Apr 2009, 09:23 pmThe implication being anything with tubes must sound better than anything without tubes, because most folks prefer tubes....Seriously, most people have a mind broad enough to comprehend that tubes, like vinyl can sound like crap. But if you're so naive to believe that the world is black and white, and white is better than black, you've been suckered into a vacuum void of reality... Nevertheless there are some people who will prefer a solid state product that sounds better than something else with tubes that doesn't sound as good.Not sure where you're getting that implication. Obviously there will be some bad tube amps that are bettered by good solid state amps. On balance though, most tube amps sound better than most solid state amps.
