mini as server for MW Transporter--any special settings?
0 Members and 1 Guest are viewing this topic. Read 1220 times.
Audioclyde
Hi all,
I will soon be receiving a Mac mini which will be used as a music server to feed my MW Transporter.  I will use the firewire connection to transmit from the mini to the Transporter ("bridged" configuration).  I'm currently using my Macbook as the music server, so I know the basics of connections, etc.
I'm wondering if there are any special or key settings/configurations I need to select on the mini in order to get the best audio quality?
Thanks in advance for any input.
Randy
ted_b
Re: mini as server for MW Transporter--any special settings?
« Reply #1 on: 4 Apr 2009, 03:23 pm »
The MW Transporter has no firewire connection, only ethernet/wireless (for Squeeze Center streaming) or coax/bnc/AES-EBU/toslink for digital input to DAC section.  I wouldn't use the Transporter if you're not using Squeeze Center, you lose a lot of its value.
Audioclyde
« Reply #2 on: 4 Apr 2009, 03:40 pm »
I misspoke   :oops:, but yes I have the macbook (and will similarly connect the mini) to my Transporter via the ethernet connection for the squeezecenter streaming.
I just was curious as to whether any of the configuration settings on the mini needed to be tweeked.
Thanks.
