polypropylene caps
0 Members and 1 Guest are viewing this topic. Read 13897 times.
Raj
polypropylene caps
« on: 18 Jan 2003, 04:43 pm »
Hi,
Are the Vishay MKP 1837 Series 1% caps
http://www.rswww.com/cgi-bin/bv/browse/Module.jsp?BV_SessionID=@@@@1170756953.1042907648@@@@&BV_EngineID=ccccadchfjkjmggcfngcfkmdgkldfhn.0&3220361168=3220361168&BV_SessionID=@@@@1170756953.1042907648@@@@&BV_EngineID=ccccadchfjkjmggcfngcfkmdgkldfhn.0&catoid=-92608771
better than the evox rifa phe 426 caps
http://www.rswww.com/cgi-bin/bv/browse/Module.jsp?BV_SessionID=@@@@1170756953.1042907648@@@@&BV_EngineID=ccccadchfjkjmggcfngcfkmdgkldfhn.0&3220361386=3220361386&stockNo=4147620&prodoid=1696738
both these types are available from rs components, I'm going to use these to parrallel electrolytics. The vishay's are more expensive and I've looked at the spec's for both, however cause I don't know that much about spec's can anyone tell me which are better? I don't mind paying the extra for the vishay's (they're 88 pence each, whilst the evox are around 18 pence each). Also what does the dissipation tangent mean? Is lower better? The vishay's give the tangent in a different format. I did notice that the slew rate on the vishay's was greater than the evox caps.
Thanks in advance
Raj
Ferdi
polypropylene caps
« Reply #1 on: 18 Jan 2003, 11:44 pm »
Hi Raj, maybe a good idea to post this in the general LAB circle. That gets a wider audience. Good luck!
davidw
    • http://www.wnaudio.com
polypropylene caps
« Reply #2 on: 19 Jan 2003, 02:31 pm »
Raj, I've not experience of the Vishay's so I really don't know. However it is now possible to evaluate capacitors objectively. The methodology and a large number of results were described by Cyril Bateman in his six ( I think ) part "Capacitor Sound" article for Electronics World. I believe that you can get a CD with even more results on it than appeared in the articles. Most of the measurements confirmed what most people thought already - tantulums bad, film capacitors good, electrolytics so so but Black Gates best of type. What was a surprise is that non polar electrolytics are almost as good as the best film capacitors.
