Perreaux Launches the World's Most Powerful Integrated Amplifier
0 Members and 1 Guest are viewing this topic. Read 4193 times.
Perreaux
    • Perreaux - High End Audio Amplifiers for Audiophiles
New Zealand hi fi amplifier manufacturer Perreaux is proud to announce the launch of the eloquence range, including the 250i - the world's most powerful Class-AB integrated amplifier.
"The 250i delivers in excess of 350 Watts of continuous power into an 8 Ohm load before clipping," says Perreaux Engineering Manager, Clinton Jensen, "making it the most powerful Class-AB integrated amplifier in the world."
The 250i features a custom-designed 1000VA toroid power transformer, with an XQ core and magnetic shielding, to provide low electrical and mechanical noise, while offering well-regulated voltage and enormous amounts of current.
A low-impedance power supply, along with high-current MOSFET output devices and Class-A signal stages, result in a sound that is "dynamic, commanding and resolute"; according to Martin van Rooyen, Perreaux Managing Director.
"Power delivery of the eloquence 250i Integrated Amplifier is totally effortless and remarkably clean," continues van Rooyen, "you find yourself continually wanting to turn it up and enjoy the music."
The eloquence 250i is a sophisticated amplifier with many features, including input volume trim, initial volume, maximum volume limit, home theatre bypass, non-invasive balance control, customizable input labels, and more - all accessible via the intuitive user interface.
Solid construction and build quality has always been a Perreaux hallmark and the eloquence 250i Integrated Amplifier is no exception; the rugged chassis design, 18mm thick milled aluminum front panel, massive custom heat sinks and unique surface finish exudes luxury and ensures a lifetime of trouble-free operation.
The 250i's compact little brother, the eloquence 150i, is rated at 150 Watts into 8 Ohms and 300 Watts into 4 Ohms, and retains the same sonic characteristics, intuitive user interface and luxurious fit and finish.
Both eloquence integrated amplifiers are available with an optional 24-bit/192kHz Digital to Analogue Converter (DAC) - ensuring complete integration of digital source components, such as network music servers and set-top digital receivers, into a high-performance music system; as well as an optional Moving Magnet (MM) and Moving Coil (MC) Phono Stage allowing connection of a turntable.
The eloquence 250i Integrated Amplifier is priced at $8,999 USD and the 150i at $5,999 USD, both are available now.  The optional DAC is $999 USD and Phono Stage $499 USD.
For further information, including dealer or other trade inquiries, contact:
Walter Swanbon
Fidelis AV
14 East Broadway, Derry, NH 03038, USA
tel: 603-437-4769
email: [email protected]
or visit the Perreaux website at
http://www.perreaux.com/
« Last Edit: 27 May 2009, 10:53 am by Perreaux »
Zero
Wow. I *just* finished reviewing the big daddy McIntosh MA7000 integrate (250wpc into 8, 4, and 2 ohms). It's one hefty beast fo' sho'. It would be very interesting to hear how the two monstrous amps compare side by side!
denjo
It is heartening to note that more and more manufacturers are realising that the cornerstone of a musical system can revolve around the humble integrated, which is simple to use and convenient. I am also glad to see other useful features like the option of  a DAC and phono! Well done!
Best regards
Dennis
Perreaux
Thanks Dennis.  It's funny, the intial design brief of the eloquence range of integrated amplifiers was for a 250W amplifier only, without any options at all or the 150i!!  We look back now to that moment 18 months ago and realise how blind we were.
With the way things are progressing on the digital side, particularly as internet bandwidth improves and high-res becomes mainstream, it would have been suicidal not to include the DAC option.  And as it turns out, the DAC module is what has fired up most people we've talked to about the eloquence amplifiers.
