0 Members and 1 Guest are viewing this topic. Read 6868 times.
I will have something to post soon.
And I have promoted the TWO equalizations.1) For CDWG on2) For CDWG offThe CDWG provides the "anyplace in the room" sonic with wide sweet spot(s), but at the expense of overall volume (since part of each panel is blocked)Removing the CDWG for those "SOLO" listening sessions will surely reduce the sweet spot, but also increases precision imaging. (my favorite thing)
When I take them off I am just removing the EQ boost present for having them on. Is there a special setting that you use with the waveguides off?
Quote from: John Casler on 1 Apr 2009, 07:38 pmAnd I have promoted the TWO equalizations.1) For CDWG on2) For CDWG offThe CDWG provides the "anyplace in the room" sonic with wide sweet spot(s), but at the expense of overall volume (since part of each panel is blocked)Removing the CDWG for those "SOLO" listening sessions will surely reduce the sweet spot, but also increases precision imaging. (my favorite thing)I had been listening with the CDWGs off before I went digital for the reasons you mention here. But, I now find that with the DCX and the EQ I prefer them on and for the same reasons I used to like them off. I have only done a little A/B listening this way, but so far I definitely prefer them on. That is good as they do look much better this way.When I take them off I am just removing the EQ boost present for having them on. Is there a special setting that you use with the waveguides off?
Quote from: Housteau on 2 Apr 2009, 06:20 amWhen I take them off I am just removing the EQ boost present for having them on. Is there a special setting that you use with the waveguides off?I am also interested in the answer to this. Like Dave, I have been listening with the waveguides on because that is what the settings on the Behringer are optimized for. It would be nice to have the flexibility to take one or both waveguides off and retain optimization.Paul
The digilog wire is 18 gauge and designed for the mid frequencies.
3) And it gets a bit more sticky here, but removing the wave guides will introduce "beaming" which is actually a desired affect for those who sit with the "head in vice" listening position (ME ) and if you want to broaden this a bit (at the cost of the precision imaging) you may have to adjust phasing, slopes, and orders, so the one to guide you would be Big B.
Quote from: John Casler on 2 Apr 2009, 05:57 pm 3) And it gets a bit more sticky here, but removing the wave guides will introduce "beaming" which is actually a desired affect for those who sit with the "head in vice" listening position (ME ) and if you want to broaden this a bit (at the cost of the precision imaging) you may have to adjust phasing, slopes, and orders, so the one to guide you would be Big B.I listen to music in pretty much the same way you do. There is one chair in my dedicated room, with the entire room designed around where that chair sits. To take that one further, the room itself is separate from the house being its own structure. I used to think that if I had a system set-up in an actual domestic livingroom my listening habits might be a little different, with more thought given to multiple listening positions and background music, along with that within the sweetspot. In such a system I thought the waveguide theory would be an optimum choice to hit those multiple targets.However, in my room from the sweetspot the choice became obvious that the best presentation of everything I valued was there with the waveguides off. Now with the modified DCX this has all changed. Brian's EQ setting for having the waveguides on actually sounds better than when I had them off. That setting fills in that void in the music created by the waveguide. That precise imaging I value is there, everything is there and it is better overall.Given some time and the desire I am sure a new setting could be found to bring listening with the guides off more interesting once again. But, that is a project for another day, or month.
