0 Members and 1 Guest are viewing this topic. Read 11763 times.
At this point I don't really have one. I buy at the point where I can do the needed job well, without going overboard. So if it costs $500 to power a pair of HT3's, then I either pony it up, or move down. If it costs $2k, I make the same decision. There's an Emotiva 5 channel amp that will throw 200W into 8ohms all day long for like 700 bucks. If that would work, that's probly my "bang for the buck" option, as its a fairly quality piece at a fair price. If I can spend 1k or 1500 and get something even better, I'd consider that too. I guess it just depends on the views presented and the reasons behind them, of what tier I'll be shopping in. I'd like to spend no more than 1500 bucks if at all possible, but if there's a "can't miss" setup out there at 2K then I'll consider it.
I've gradually modified the HT3 crossover to be more amp-friendly. The current model has a minimum impedance about 1.5 ohms higher than past HT3's
Had a good conversation with Jim this afternoon about his product line. Most informative 30 minutes of my upgrade-itis adventure, a real pleasure to talk to. In particular, he was very high on his HT2 line, and how easy they were to drive and place in a room. So as far as driving those, I won't have much problem picking something out if I go that route. I'm curious as to what HT3 owners:1. Consider "enough" power for their HT3's (whether 200w or 500w+)2. Use as an amp to achieve such power.3. Do you bi-wire, and if so, how is this set up in your system?I'd probly like to stick with SS for my application over tubes, but if you have tube systems that are reasonably priced and think I should give thought to as I consider my new system, please comment. I'm aware of the fact that HT3's have a lower requirement for tubes rather than SS, and although I don't understand why, its still with me so I'm not out there looking for a 500W tube system.
Yes Dennis, and I know I asked this before but when did you make the change to the crossover?The HT3s are a blessing and a curse. LOL. They just pass along whatever is upstream and I'm always impressed how I can hear every little change in gear. Right now I've borrowed a Bel Canto Evo4 mkII amp from a friend that sounds very fine. But I'm not sure I would like it without my tube pre and tubed disc player. It might be a bit dry without the tube front end. As it is now it is very nice.
Well, in my experience, the best amp with the HT3's was the BAT VK600SE. It is darn pricey, but nothing touched it on my HT3's.Some other good choices at more moderate prices are:- McCormack DNA-500- CI Audio D-200's- Moscode 401HRGeorge
