0 Members and 1 Guest are viewing this topic. Read 7287 times.
swg25,The setup I listened to was not mine,so you are probably more correct then I. But in this room the larger sub made it shine.Larry
Redbone, I recently purchased a used Odyssey Stratos with the cap upgrade, and also replaced my DIY-type cables with Odyssey's own Groneberg interconnects and speaker cables. I also had Klaus make me a short pair of "jumpers" to bypass the biamp switch on the speakers. The difference is so incredible that it's hard to put into words. I've had the flu all of the last week and the worst part isn't the way I feel (although I feel like crap), it's that my head's so stuffed up I can't enjoy my new ...
Okay, so I'm a freakin idiot. Sometimes I wonder what I'm doing with speakers like this in the first place. I just hooked up my old speakers for a sound check, no sound. Huh ? To make a long story a bit shorter, I installed these speaker cables over 10 years ago when I bought the house. I soldered the ends (with electrical solder I hope) to keep them clean but they are quite tarnished now. So I cut off the old ends of the cables and stripped off about 3/4" of clean, shiny copper wire. What a diff ...
