0 Members and 1 Guest are viewing this topic. Read 34186 times.
Quote from: Steve on 30 Mar 2009, 02:31 amI agree with many of the sentiments posted earlier. If I may, I would like to introduce a couple of other factors.1) The DA (dielectric absorption) of a solid state device is much higher than that of a tube since a tube uses a vacuum as the dielectric.2) The power supply capacitors I have seen in most or all stages of solid state amplification is of the electrolytic variety. This means the DA and ESR is much higher than that of film type capacitors that is often used in tube components.Just a couple of more points to consider.Hope this helps solve the sonic differences.SteveTrue, and what's worse is that in most complimentary SS amps the last cap(s) in the PSU are in the (AC) signal path (current loop), which are usually 'lytics, even though the amps are DC coupled. The same is true for SET amps, that the last cap in the PSU is in the AC current loop, but most builders recognize this and use good quality film cap as the last PSU cap.
IMO, I think that the blanket statements about tubes and solid state no longer really apply. I think the design/advancement of each has been quite astounding. There is plenty of tube gear that some would call "solid state like" and plenty of solid state gear that one could say "has tube like warmth or midrange." I know that over the last few months my eyes (and more importantly ears) have really been opened up to this. I have certainly heard solid state gear that I would call more musical than tube gear, and to me, ultimate musicality is paramount. I truly believe that the vast majority of the sound of a particular component is greater determined by the designer of the piece and the voicing they create than some of the nuts and bolts used. Just my $.02
ear candy wins out over eye candy, when it comes to audio equipment. doug s.
Voltage is your friend, current is your enemy
Quote from: doug s. on 30 Mar 2009, 02:46 pmear candy wins out over eye candy, when it comes to audio equipment. doug s.I wouldn't disagree a bit. I never said that looks won out, merely that I like the fact that my amp looks great and sounds great.
Our ears are not averse to tube harmonic distortion.
It's all in the topology...You can design a tube amp to sound just as bad as a solid state amp, or you can design a solid state amp to sound just as bad as a tube amp
i don't disagree w/you either - i wish my melos pre looks as nice as the cary it replaced! doug s.
