faceplates
0 Members and 1 Guest are viewing this topic. Read 3473 times.
alexone
faceplates
« on: 24 Mar 2009, 07:15 am »
James,
what are the costs for changing the faceplate for (each):
- BCD1
- BDA1
- BP26
- 4BSST
thanx,
al.
alexone
Re: faceplates
« Reply #1 on: 24 Mar 2009, 10:32 am »
James,
- BCD1
- BDA1
- BP26
- 4BSST
thanx,
al.
...and what happens to the exchanged faceplates? would i get 'em back or do they go back to Bryston? :o
it would be very cool to have 'em home  :thumb:!
al.
  • The Demo is Everything!
    • http://www.bryston.com
Re: faceplates
« Reply #2 on: 24 Mar 2009, 11:24 am »
Hi Alex,
Faceplates vary from $100 US to $300 depending on size.The 4B is 200 and a set of handles is $100.  The BP26 is $100, MPS2 $100 and the 3 knobs are $100.  The DAC and CD Player are $100.
I would not recommend trying to change them in the field though as aligning the leds in the BDA one and the draw and leds in the CD Player is not an easy task. Also to change the amp faceplates you have to remove the heatsinks and disassemble the amplifier to get at the bolts that hold the faceplate on.
james
alexone
Re: faceplates
« Reply #3 on: 24 Mar 2009, 11:33 am »
Hi Alex,
james
James,
i wouldn't try to do it by myself. i thought the distributor is the one to do it...or is he not?
al.
Re: faceplates
« Reply #4 on: 24 Mar 2009, 12:49 pm »
Sun could do it.
james
1ZIP
Re: faceplates
« Reply #5 on: 24 Mar 2009, 02:03 pm »
James;
Wow....I'm glad this topic came up!  I was just about to try and do it myself.  The closest dealer to me is Fred's in Portland, OR and I doubt if they would attempt to open a 4B ST.
danman
Re: faceplates
« Reply #6 on: 24 Mar 2009, 02:41 pm »
1ZIP I did my 4B-ST myself and it was easy. Mike Pickett from Bryston sent me the instructions and I still have them if you would like to see them.
1ZIP
Re: faceplates
« Reply #7 on: 25 Mar 2009, 02:26 am »
Danman;
Thank you, that's very kind of you.  I'll try and send you a PM.
qkot
Re: faceplates
« Reply #8 on: 29 Jan 2010, 01:34 pm »
James, if I want to change a silver 19 inch BP26 to a silver 17 inch do I need to purchase new knobs? I assume they are the same?
thanks
Re: faceplates
« Reply #9 on: 29 Jan 2010, 01:45 pm »
thanks
Knobs are the same.
james
vegasdave
Re: faceplates
« Reply #10 on: 31 Jan 2010, 08:30 pm »
James, I still need my dented faceplate replaced. Is it too late?
Re: faceplates
« Reply #11 on: 31 Jan 2010, 09:58 pm »
Dave - for you anything. :D
james
werd
Re: faceplates
« Reply #12 on: 31 Jan 2010, 11:11 pm »
you should use that as your avatar for awhile..... that would be  8)
vegasdave
Re: faceplates
« Reply #13 on: 1 Feb 2010, 01:54 am »
james
haha. That's good to know!   8)  8)
Stu Pitt
Re: faceplates
« Reply #14 on: 1 Feb 2010, 04:11 am »
Dave - ask him to send me a BDA-1, free of charge.
vegasdave
Re: faceplates
« Reply #15 on: 1 Feb 2010, 06:55 am »
Ok! haha.
