0 Members and 1 Guest are viewing this topic. Read 34416 times.
Somehow your library index file got corrupted. From within iTunes, delete ALL the songs in your library but DO NOT move to trash when asked. Once done, click File -> Add to Library and point to the folder on your drive that contains all artist sub-folders, click OK. It'll re-index your library.Edit: I'd like to make this a sticky topic as it comes up from time to time.
Quote from: Crimson on 22 Mar 2009, 11:21 pmSomehow your library index file got corrupted. From within iTunes, delete ALL the songs in your library but DO NOT move to trash when asked. Once done, click File -> Add to Library and point to the folder on your drive that contains all artist sub-folders, click OK. It'll re-index your library.Edit: I'd like to make this a sticky topic as it comes up from time to time.This works, but be aware that if you do this, you will lose some of your metadata, including play counts, "last played", and ratings. This information is stored in the iTunes database, not in the ID3 tags.
If you want to avoid this in the future, you might want to do what I do, which is to run a simple batch file after any updating of iTunes to backup and copy to another location the .itl, .itdb and .xml files located in the iTunes folder in your user profile.
Quote from: srb on 22 Mar 2009, 11:59 pmIf you want to avoid this in the future, you might want to do what I do, which is to run a simple batch file after any updating of iTunes to backup and copy to another location the .itl, .itdb and .xml files located in the iTunes folder in your user profile.Great advice. Whether it's a batch file or an Apple script (), even manually copying the index files to a backup location can help alleviate this issue.
