Hardwired FLEX TX102 pre-amp looking for a home.
John Chapman
    • http://www.bentaudio.com
« on: 20 Mar 2009, 04:48 pm »
Hello!
I had a few S&B TX102's that I took on trade from an OEM - and a couple were built into pre-amps using FLEX cases. This is the last one using TX012  transformers. It's a pair of fresh (New Old Stock I suppose!) S&B TX102 MK I transformers in a FLEX case. Built about 2 weeks back and burned in and ready to go now. Here are the specs:
1- Shallco switch with remote control for volume
2- 6 Inputs (with Shallco source select) - 4RCA + 2 XLR
3- Dual RCA + Dual XLR outputs
The internals are the same as my NOH pre-amp used - just now in a FLEX Case instead. I figured about $1200 should be a really good price for it. A similar NOH would have sold for $1700 a couple years back and was considered a bargain then! Expected home would be someone who has a mix of xlr bal and rca sources and either bal or rca inputs on the amps.
Just e-mail or call for more info, etc...
Thansk!
John
John Chapman
Re: Hardwired FLEX TX102 pre-amp looking for a home.
« Reply #1 on: 21 Mar 2009, 03:31 pm »
Hello!
The pre-amp has found a new home....
Thansk!
John
