Auricaps/Aura-T teflon caps vs. Vcap Teflon capacitors
Lizard_King
  • Tubes Rule!
The Audience Auricaps are highly regarded film capacttors that are liked by DIY's and audiophiles. Audience also makes the Aura-T Teflon capacitors which are really high end and costly. The Audience caps are good performing, reasonably cost and very reliable. I belive that can be said about their Teflon series caps.
VCaps are a brand that are teflon and better priced than the Aura-T capacitors. I do not know about their reliability. Do you think the Vcap Teflon caps wit the midline price point are better to use than the Auricaps and also, the Aura-T teflon caps?
Thanks in Advance.
« Last Edit: 17 Mar 2009, 04:55 am by Lizard_King »
