For you food guys - The best way to clean fresh corn........... ;)
0 Members and 1 Guest are viewing this topic. Read 7186 times.
PhilNYC
Steam/boil it for 12 minutes.  The sooner you can get it cooked after cutting it from the stalk the better....
12 MINUTES?!  :o
Geezus, you might as well buy canned or frozen if you're going to boil or steam it that long.  :wink:
3 minutes in boiling water, tops, then onto the plate and eat immediately. If the ears are a day (or more) old, you can add some sugar to the water. But never, ever, add salt, it makes the skin of the kernels tough.
Sorry...I've tried as little as 6 minutes, and the result was WAY undercooked for my taste.  And as a response to your comment, I'll say that if the ears a day-old (or more), you may as well buy canned or frozen...the sugar in corn turns to starch incredibly fast; imho, if it's not in the cooker within a couple of hours of being cut from the stalk, the sweetness drops WAY off...!
3 minutes?  You may was well not even cook it...  :P
(fwiw, my only experience with this is with NJ sweet corn...)
PhilNYC
Put the corn on the top shelf (warming shelf?) in your gas grill, unshucked (in husk for you city kids) for about 20-25 minutes.  Yes it is a bit warm when you do peel and de-silk, but the silk comes off really easy now.  And the flavor is well worth the heat to your fingers while cleaning :drool:
I've not tried it, but someone suggested this method to me, adding that soaking the ears in milk beforehand is a great idea...
Mr Content
Well I will try all these methods and times, and see what I like most. Thanks :drool:
Mr C aa
