0 Members and 1 Guest are viewing this topic. Read 9577 times.
hi I'm looking for a good pair of bass drivers myself to complement my atc mids and scanspeak tweeters, the peerless look like they could fill the hole...how do you think they compair to the popular Eminence 15''sas for build quality i know they must have the edge but what brings them up in the sound department ?thanks..mike
Cool! My single Peerless will play flat down to 40Hz then drop off fast. Not to bad, really. Baffle is 15"x28"10mH, that's a wopper for two drivers in parallel (4 ohms). But it can take that much to get a good tonal balance. Nice work!
Fivestring,I like your system configuration, personally I prefer a more efficient drivers.Questions please:a There is a dip around 1Khz, do you think this would make much difference to the sound?b In general terms do you normally design on-axis Freq. response curve to be flat or dip around 1-2dB above certain freq.?Cheers.
It has wings, asymetrical. To get any lower, it would need a deep U. But I have found that to bring up only the mid bass, and THAT I have plenty of! Getting it to go down another octave, or even a 1/2 is going to be tough. I don't even know how low the Peerless will play in a box. Flat to 40 Hz isn't too bad, really.
Fivestring,I like your system configuration, personally I perfer a more effcient drivers.Questions please:a There is a dip around 1Khz, do you think this would make much diffrence to the sound?b In general terms do you normally design on-axis Freq. response curve to be flat or dip around 1-2dB above certain freq.?Cheers.
yes, that Peerless duo is awesome! Between 40-300 Hz everything sounds extremely clear (the baffle is very stiff), with proper weight, blah blah, you know...
Could you send me pictures of your OBs?
Quote from: Telstar on 19 Mar 2009, 11:05 amCould you send me pictures of your OBs? I'll post some. Not pretty, though....
