Applying NOH updates to TX102
0 Members and 1 Guest are viewing this topic. Read 2449 times.
Al Garay
« on: 9 Dec 2003, 07:57 am »
Hi John,
Just looked over your site and noticed the following features offered with your NOH pre-amp:
* switched headphone output
* +6db gain switch
Can these be done to the TX102?
Might need to make another visit after I receive my  new Ack! DAC.
Al Garay
John Chapman
    • http://www.bentaudio.com
« Reply #1 on: 9 Dec 2003, 08:10 pm »
Hello!
The internal wiring of the version you have is the same as the NOH so we can add any of the stuff you'd like. Just give me a shout when you want to drop by and mke the mods - it'd be good to see you again! I think you'll like the ACK!. It sounded really good when i got to hear one a week or so ago.
Thansk!
John
Al Garay
« Reply #2 on: 9 Dec 2003, 08:18 pm »
Thanks. I will check back with you after Christmas. Meanwhile, enjoy the Holidays with your family.
Al
John Chapman
« Reply #3 on: 9 Dec 2003, 08:35 pm »
Hello!
I look forward to it and all the best to you as well!
John
