Do You Squeezebox Guys Leave Your Computer On
0 Members and 1 Guest are viewing this topic. Read 6208 times.
cloudbaseracer
Re: Do You Squeezebox Guys Leave Your Computer On
« Reply #20 on: 4 Mar 2009, 02:44 pm »
The laptop is my everyday unit but would not be used for storing files or running SqueezeCenter.  I think I see what you mean about running the desktop headless.  I would think that the burner in a newer desktop would be better than the one in my 3 year old laptop?  Maybe that does not matter if using a program that scans the disc multiple times and tries to ensure a 100% read.
Pretty much any desktop will come with at least a keyboard and mouse.  I don't envision loading a huge number of discs after the initial set-up so it should not be much of a problem if I locate the desktop in the mechanical room -- it does not have the comforts of an office!!
James
Dan Driscoll
« Reply #21 on: 4 Mar 2009, 05:39 pm »
I leave my home PC off during the week, unless I'm using it. I generally don't have time to listen to music weekday evenings, so there's no point in leaving it on. Weekends I usually do leave it on.
