ARMod II turntable project begins.
0 Members and 1 Guest are viewing this topic. Read 17974 times.
charmerci
Re: ARMod II turntable project begins.
« Reply #60 on: 8 May 2009, 03:46 pm »
What's a dead man weight? (I hope it has nothing to do with murder!  :icon_lol:) Was it that silver cylinder in the visible tennis ball photos?
Looks great.
Wayner
« Reply #61 on: 8 May 2009, 03:50 pm »
It's a lead weight that is used to replace the broken anti-skating mechanism in the Rega R200 tonearm. If you go back a page or 2, you will see a close-up of it.
Wayner
Brett Buck
« Reply #62 on: 8 May 2009, 04:10 pm »
  On that topic, looking at the picture, does the thread just go through the eye and slide through it? Don't you get stick/slip motion?  I would think you would need a pulley instead of sliding.
      Brett
Wayner
« Reply #63 on: 8 May 2009, 06:59 pm »
Brett,
There is a very tiny washer underneath the lead weight that has the thread tied to it. That thread goes thru the lead weight, then thru the eyelet and then over to the tone arm pivot (to the outside). There is also a guitar string (high E) that runs from the plinth up thru the lead weight and into the eyelet. This "E-string" keeps the lead weight from swinging back and forth. The thread is about 2 lb test fishing line and has almost zero resistance thru the eyelet. As you swing the arm back and forth, the weight moves up and down. It really works great.
Wayner
Brett Buck
« Reply #64 on: 13 May 2009, 05:30 am »
    Oh, I get the mechanics of it, I have had several that were of the same general design. But they also had pulleys at the point where yours is sliding. I have retrofitted other people's with teflon dental floss to reduce the stick/slip motion when it slides. In some cases, you could see it stick and slip. We also used a rolling-contact on the tonearm side so the moment arm (and thus the torque) stayed the same throughout the travel. Without that,  the effect is minimized if the thread is 90 degrees from the tonearm axis at the center of travel. Or you can make it a cam if you want to have the anti-skate vary predictably over the travel of the arm.
     If you are interested, and you send me the dimensions (mostly, the height) I would be glad to take a stab at building a pulley and stand system. The rolling contact part, you are on your own. Not on any schedule, however - I got a lot of airplane stuff to work on in the next few months.
     Brett
