speaker cables under $200?
0 Members and 1 Guest are viewing this topic. Read 6583 times.
ton1313
« Reply #20 on: 8 Dec 2003, 10:43 pm »
There is a 10' pair of Zu Julian on ebay right now. It is at $76, auction ends in about 1 hour. These retail at @$240 for a 2.5M pair.
Jetsons
« Reply #21 on: 10 Dec 2003, 03:04 am »
Here is the old version AQ Slate terminated with the AQ copper spades on close out, http://www.hcmaudio.com/comp.asp?compID=521
I had the current "new & improved" version and it sounded dark in my system. This was not the case with the old version which replaced the DIY 12awg equivalent plenum Cat5s.
Jet
Jetsons
« Reply #22 on: 10 Dec 2003, 03:13 am »
With regard to the Audioquest GR8, it has been discontinued for quite some time. I believe HCM has been running the GR8 deal for an easy two years.
I decided not try this cable as the individual wires are stranded as opposed to my preference to solid cores which are used in the other AQ models. I believe the insulation on this cable is entirely PVC. It does look impressive for the cash!
Jet
