0 Members and 1 Guest are viewing this topic. Read 13042 times.
With respect to your first plot, if you moved the driver off center in the 25 cm wide baffle I bet the dip would be greatly reduced.
For a 3" driver which needs to be crossed over to a woofer anyway, why wouldn't you use the 40 cm wide baffle and design a crossover to roll off the low end at a selected frequency? Why would you want to require both EQ and a crossover to make the 11.5 cm baffle work?
With respect to the second set of plots, I am assuming the nulls above 5 kHz are due to lobing caused by the driver diameter.
And the final EDGE plot, the driver is in the center of a circular baffle so I am not sure why this is important to show.
Please excuse me for saying this, but it seems you are making selecting a width during the design of an OB much more difficult then required. ... I see many DIYers get too focused on perceived problems and expend significant energy to address something that will be lost in the bigger picture that is the final in-room SPL response. I am sorry but I still just don't get the advantage of a narrow baffle on the order of two times the driver diameter.
thanks guys,your systems are not that simple i see. electronic crossover, active Xover.... biamped...well i might buy something like that to, (like the berhinger)the advantage is that you can always tune it if you like, (otherwise there isn't ? or is there ?)so you split the signal in an electronic crossover between sub and fullranger then it would be best to flatten the bass as good as possible (like the t1951)i suppose you don't use an digital crossover (like dec2496) because the quality loss in conversion ?)but if you have 2 amps behind the crossover: how do you manipulate the volume or do you do this before the crossover ?thanks
