What is the different between Yamamoto YC-03S and YC-03M? (Phono Cartridge)
0 Members and 1 Guest are viewing this topic. Read 3157 times.
Bursabaju
    • Bursabaju.com
Will anybody help me to describe the difference between Yamamoto YC-03 S and YC-03 M ? (Phono Cartridge)
Which one is better? because both on the same price.
Thank you.
macrojack
I do not know the answer to your question but it seems likely that M is mono and S is stereo.
Bursabaju
    • Bursabaju.com
Yes, M for Mono and S for Stereo.
What is the difference for the sound quality?
I don't really get the meaning of Mono and Stereo.
Because I am still a Newbie in this home audio.
Anyone could help me to get the answer.
Jampot
If you read the history of monaural sound here -
http://en.wikipedia.org/wiki/Monaural
and the explanation of stereo here -
http://en.wikipedia.org/wiki/Stereophonic_sound
you will perhaps understand better that the question is not one of quality but compatability of the cartridge with your disks. Unless you have a collection of vintage 'mono' recordings you don't want the YC-03 M.
Jim
Bursabaju
    • Bursabaju.com
Thank you Mr. Jampot,
So, which one is better from your opinion?
The Mono one, or Stereo one? If I saw on the wikipedia, that mono means disc or record made before 1970..and I do not have this records...
Is it better for me to take the Stereo one?
Thank you.
Jampot
Yes, You need the stereo one :thumb:
Is the arm on your tt suitable - I don't know how much the Yamamoto is but I suspect expensive and it may not be the best match for your system.
Jim
