Matching surrounds for Protege Vs fronts
zheka
« on: 19 Feb 2009, 09:42 pm »
This one is for Mike Dzurko or for anybody who cares to offer advice.
I am putting together a home theater speaker system. I already have a pair of ACI Protege Vs for fronts ,  Protege center, and Force sub
I am now looking for surrounds. What would you recommend me to get? Would Descants be an acceptable option? Or should I try older Emeralds? If Emeralds, does it matter what model it is? I am not too concerned with esthetics, but I want the speakers to match well sonically.
Thank you
gene
Mike Dzurko
Re: Matching surrounds for Protege Vs fronts
« Reply #1 on: 20 Feb 2009, 01:15 pm »
Gene:
On walls or inwalls are certainly a viable option for surrounds. Pretty much any vintage Emerald will do a great job as well. You already have the most important parts of the equation well handled  :D
zheka
« Reply #2 on: 20 Feb 2009, 01:31 pm »
Gene:
Mike,
Thank you very much!
