ground loop hum from cable tv
0 Members and 1 Guest are viewing this topic. Read 3700 times.
drphoto
« on: 6 Dec 2003, 07:14 pm »
I tried to run sound from my tv to my 2 ch audio. I get a nasty ground loop hum from the TV cable. How can I get around this? Drive a new ground stake and attach the cable ground wire to it?
Tonto Yoder
drphoto
« Reply #2 on: 6 Dec 2003, 07:59 pm »
Thanks Tonto. That's an easy fix, and there was a lot of other good info linked from that site.
Tonto Yoder
« Reply #3 on: 6 Dec 2003, 09:12 pm »
There are also the mystery black boxes---Mondial M.A.G.I.C & something by Tributaries--designed to address cable hum, but they're in the $100 ballpark.  I'm unsure if they have some extra circuitry that makes them more effective or if they're the same transformers in a pretty box????
I'd be inclined to try the Radio Shack/DIY route first.
Mad DOg
« Reply #4 on: 6 Dec 2003, 09:26 pm »
Quote from: Tonto Yoder
the rat shack DIY solution does the trick for cheap...
Tonto Yoder
« Reply #5 on: 6 Dec 2003, 09:35 pm »
Cheap?? Cheap???
Any real audiophile is gonna replace those F connectors with BNC's, the wire with some Cardas, put the transformers on some isolation platform,
shield with ERS and damp vibrations with some Josephson barbell-mass loading. :D
Espo
« Reply #6 on: 6 Dec 2003, 11:28 pm »
Does this fix limit the bandwidth for digital cable TV?  I thought the Jensen VRD-1FF for about  50 bucks was a good solution since the bandwidth goes up to 1300 mhz? :?:
wreilly
« Reply #7 on: 7 Dec 2003, 11:53 am »
I have the Mondial Magic, it's pricy but itt's the best one Iv seen. Works great on Digital Cable.
HifiDan
Ground Loop
« Reply #8 on: 7 Feb 2004, 07:17 pm »
I had the same problem. I got an isolator ground cable transfo. It is about 1 inch in dia and about 3 inches long,and it's made of aluminium. I guess  there are 2 coils and the ground is lifted. There is no name on it thou.  Works very well and it's only 14.95 CDN.
I got mine at an audio shop doing bar and disco installation. Apparently they use this a lot with Sat dish, etc.
Kill the hum ...
Hifidan
The 75/300 Ohms thing doesn't work with digital t.v and you loose at least 10 db of signal going this route.
vpolineni
« Reply #9 on: 17 Mar 2004, 05:57 am »
I just noticed that I have the same problem...would this work?
http://www.audiocircle.com/index.php?topic=7417&highlight=hum
Rob Babcock
« Reply #10 on: 17 Mar 2004, 07:34 am »
Yep.  I bought one from him and it works like a charm.  The ground loop caused by my cable was bad enough that I disconnected it when I wasn't watching TV.  But that little thing fixed it right up! :thumb:
