0 Members and 1 Guest are viewing this topic. Read 42166 times.
There are a handful of folks who actually know something about capacitors in the USA. Most of them won't discuss matters with common consumers. A few of them will chat briefly. If you would like further eduction on these matters, I might suggest a telephone call with George Short, Chris VH, or Jeff Glowacki. I have learned to trust Jeff Glowacki (www.soniccraft.com) over the years, but I certainly acknowledge that he is not the only person having accessible knowledge on these matters. Jeff does have significantly better measuring equipment and has objectively quantified component differences.
(decades, actually; I turned 65 yesterday ),
We know that with rising frequency, the electrons will reach for the surface.
Perhaps I can get him to share his thoughts on the original subject of inductors.
One thing to mention would be the original crossover inductors were mounted at the proper 90 degree orientation about 3 inches apart. My upgraded version ended up with about 9 inches between inductors - also at the 90 degree orientation.
Another page with some inductor interaction measurements: http://www.troelsgravesen.dk/coils.htm
Hey Dave,I ran across your site while searching for information on copper foil inductors. Very impressive speakers - I bet they sound as good as they look! My question for you involves the use of Alpha Core foil inductors versus something like Solen Perfect-Lay or other simular designs. I joined the open-baffle crowd last year with the purchase of a pair of Hawthorne Audio Silver Iris drivers. The stock crossovers of their entry product are well built with what I would call medium-grade components to keep the costs down. I recently made a new set of crossovers using Alpha Core copper foil inductors and Clarity PX grade caps. The difference was rather larger than expected and in the case of the foil inductor paralleling the tweeter runs counter to some folks wisdom. Empirically it works, but there is a lack of general information on the web supporting the use of conventional round wire versus foil in this application. Opinions seem to be more common. So, my question is along these lines. Do you have any hard measurable benefits to using foil over wire in this application? Listening tests count too. When the hearing is backed up by science it is always nice.I appreciate any time you may have to reply.Thanks,Robert Pace
Quote We know that with rising frequency, the electrons will reach for the surface. Hmmm, I have never heard/seen it expressed in this fashion previously, but I suppose this is reasonable. I have always seen and convey the inverse statement - that lower frequencies and higher power require a larger gauge cable due to increased saturation. Hence, the abundance of electrons need a bigger wire.
4) Thin foil does not have the skin effect seen in solid conductors larger than 23AWG in the audio band.
