Slagleformer Men - two prototype units on sale.
John Chapman
    • http://www.bentaudio.com
« on: 16 Feb 2009, 05:11 pm »
Hello!
Few weeks back I found time to build two of the Slagleformer Man modules into a couple FLEX enclosures as a way to play with them here. I built them single RCA input / dual RCA output. I'll be taking some pics today - so if you are interested just e-mail and I will send them to you.  Like all these things now that the testing is done I should find a new home for them. Also now that the work is already done and since the case parts were stock I can price these ones kinda lower than they otherwise be priced...... Lets say $450 each.  That's only $100 over the introductory price of the autoformer modules to get the FLEX case, Knobs, jacks, and building and testing time here. Not a bad deal I think. Only these two will be sold like this.
These use the Slaglefomer Manual units Dave sells now as diy parts. They don't have remote control - but that was the whole point of the Slagleformer MAN units - to be a cost effective alternate to the modules used in the TAP-X. These have 36 volume steps using a main level control then a trim control. They are dual mono controls - separate left and right level controls so you can adjust balance.  If you wanted to get parts to expand the number of inputs yourself using these FLEX chassis based units as a shell that would work fine too. Just call or e-mail and we can make a plan to suit your needs.
Info on these modules can be found in these links:
http://www.audiocircle.com/index.php?topic=60664.0
http://intactaudio.com/module.html
and the basic FLEX chassis looks like this:
http://bentaudio.com/index2.html (go to the FLEX Chassis link)
Thansk!
John
« Last Edit: 5 Mar 2009, 07:08 pm by John Chapman »
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
Re: Slagleformer Men - two prototype units on sale.
« Reply #1 on: 5 Aug 2009, 04:35 am »
Are either of these still available?
-Tony
John Chapman
« Reply #2 on: 5 Aug 2009, 01:43 pm »
Hello!
Sorry - they are both sold now. Contact Dave Slagle at intactaudio.com to see what he has around. If you have any trouble getting ahold of him e-mail me here at [email protected] or call here and I'll get the info you'd need. Those modules are a really easy way to diy up a manual autoformer pre-amp.
Thansk!
John
