0 Members and 1 Guest are viewing this topic. Read 8767 times.
I understand Mike Galusha had your DCX for some time. His full mod takes a while to install, plus he had difficulties with the audio boards. It was your unit's vexing problems that led him to stop modding DCX's entirely.However, you now own a state of the art preamp, digital crossover, and six band parametric EQ that will work wonders with your sound. Just eliminating primary room modes is a huge step forward and is easy once you familiarize yourself with all DCX modes and functions.Remember you will still have to adjust levels between bass and treble amps, since the gain of your dissimilar amps is close, but not exactly equivalent. Go slowly in 0.1dB steps for best results.Have fun and let us know how you're doing.
The first thing that jumped out to me was increased clarity on vocals. Mike refers to it as "inteligibility" and feels it is due to the steep crossover slopes.
Hey Paul, you wouldn't happen to have any pictures of your setup available, do you? Thanks. Cheers,Robin
Paul I'd be interested in more info too. Are you running three amps or two? Are you using the digilog? How do you have it physically set up is everything in a rack with wires going out to the speakers? Do you have it set up so you easily switch back to analog?Tom Brooke
