0 Members and 1 Guest are viewing this topic. Read 6827 times.
PhilNYC - Currently with the PRE 3 I'm using balanced to the S300 and unbalanced to the JL sub. As a Bel Canto dealer do you take trade ins? Thanks.
PhilNYC-I believe I would lose the HT bypass option on the PRE3 if I went with the DAC3? One of the reasons I went with this item was to meld with a future receiver (HDMI w/front outs to the PRE3), while still utilizing the PRE3 for the fronts.
I did the same thing; stock unit then had one modified. it is amazing how much better it can get with the mods from Cullen, not Underwood, btw. Cullen builds the stock unit and knows what needs to be done to elevate it. It's a nice unit as you are experiencing.
No. Chris Johnson of Sonic Frontiers heritage does the mdifications to Walter's goods in Canada through Parts Connexion.Note that the mods Walter offers are more window dressing than anything else and in my book a big waste of dollars. How do I know this? Ruined a perfectly good amp once doing this "mod" work through Walter. Never again.Only real technical changes with the Cullen mods. Rick Cullen is a genius guys.
Is this the DAC that their blowing out right now for $695 (was $995)?
I have a PS Audio DAC3 being used as a DAC for my MacBook Pro. Coming from the cold, plug-n-play, this is one great DAC! Just in case you want to see the inside...They used high quality parts and clean board layout. No OPamps!
