db poweramp question
0 Members and 1 Guest are viewing this topic. Read 2220 times.
Pacio
« on: 14 Feb 2009, 07:05 pm »
Hello everybody,
I would like to ask you all if the specific feature of poweramp to manage HDCD files is available in its free version also. I'm asking that because I cannot find in in any menu. Is it a codec to be downloaded? Or is it available with the registered version only?
In general, how do you manage SACD files, how can you rip them at the highest resolution and feed the SB3 with them in their native resolution?
Thanks for your input!
Pacio
Bob Wilcox
Re: db poweramp question
« Reply #1 on: 15 Feb 2009, 03:37 am »
I have the reference version. There is a DSP tab at the bottom center area of the screen. From that tab, you can select HDCD.
You can't rip a SACD layer directly. You can rip the redbook layer if it exists. You can record from the analog output of a SACD player onto a PC with a hi res soundcard but the SB3 may not be able to play back higher resolution files. Or you could investigate digital recorders.
If you want to playback hi rs files, the Transporter can handle up to 192/24 files. I think the vapor PS Audio units will as well. I have tested both 176/24 and 192/24 flac and wave on the Transporter. The SB3 is more limited and may downsample some hi res files and not play others at all.
Regular CDs will often sound better played from the hard drive than from a CD player. Enlarged pictures taken of commercial CDs show land and pit variability in discs created from the same stamper.  The process of PC based ripping seems to be more thorough in getting all the data off the CDs than the servo controls on a CD player. So, assuming your drive is optimally working with EAC or dbPoweramp, you may be surprised with the quality of redbook CDs on the SB3.
Bob Wilcox
« Reply #2 on: 17 Feb 2009, 12:36 pm »
Actually the Transporter may be downsampling hi res files as well.
Pacio
« Reply #3 on: 18 Feb 2009, 01:43 pm »
Thank you for your explanation.
Actually, I only have a couple HDCDs but no SACD. I was wondering in case I would like to get a good record if I can count on SACD as well, but it seems that I can do that if it's an hybrid one.
Much appreciated!
Pacio
