0 Members and 1 Guest are viewing this topic. Read 17353 times.
Does it have to be 9 volts coming in or will it work with a higher DC voltage?The reason why I ask is because I have seen pictures of the internals of the receiver on the net, and someone mentioned that it already has 3 voltage regulators on board. So,,,,,,,, in other words, I don't want to regulate to exactly 9V if it's not necessary.Sorry to highjack the thread . . . I hope someone can answer.
Buy the Acopian and strip a power cord and DC cord and hook it up - it's easy and Acopian has the exact match in amperage that you need.
Quote from: Quiet Earth on 19 Feb 2009, 02:32 amDoes it have to be 9 volts coming in or will it work with a higher DC voltage?Well, I have submitted the question to Logitech. We'll see if they reply.
I would be shocked if they reply with an answer other than "you shouldn't be playing in there. Therefore you don't need to know".
I'm hoping to eliminate a slight grain I'm hearing and would like an increased sense of air in general
Found this:http://www.mcmelectronics.com/product/DISTRIBUTED-BY-MCM-MW122A-/28-2200Description is Multi Voltage Regulated Power SupplyIdeal for any device drawing up to 2A Fully regulated to deliver constant DC power Rotary selector switch selects 3, 41/2, 6, 71/2, 9 and 12V Power projects or small battery operated devices Color coded binding posts makes connection easyI sent a mail to MCM and they comfirmed it is a linear supply.Cost is $27.95 plus shippingKirk
Unfortunately I believe you overlooked these two features:# Built-in surge protection allows for safe car start-up and shutdown# Low battery shutdown when DC voltage falls to 10.5V or less It appears this is made to regulate battery supplied voltage.Or it could very well be that I'm the one overlooking something
Jim-Glad to hear that it's an improvement; I'll order one myself...BTW since you don't mention one, I assume you aren't using a DAC, just the analog outputs of the SB, is that right?My understanding is there is a greater difference with the linear supply when using the analog outputs.I'm using a DAC but for the price of this supply it's worth trying it just for the heck of it.Plus I can use it as a tool to help me fix my recent acquired Magnepans, but that is most definitely a different thread...Kirk
