I'm aware of these devices but haven't read up on them yet. Most of us use dedicated AC lines and AC power conditioning to prevent any crap on the AC lines from degrading our sound. Now we are sending our music data down the same lines? Is there a reason that this is not a concern? Cheers!
Many AC'ers even go to the extent of using battery powered hifi equipment in order to avoid the garbage riding on the AC lines. You HomePlug pioneers are sending your delicate music signals down these same AC lines. Have any of you done a careful A/B against a straight ethernet wire (or against wireless)?The convenience (versus trying to run ethernet cabling in existing walls) is great but ..... I'm apprehensive at this point.Do any of you have your hifi gear on dedicated AC lines but your music server on a different AC line, perhaps on another floor? Any issues ... is it better if each HomePlug device is connected to the same AC line?EDIT: Sometimes switching on/off electrical appliances or lights causes a momentary audio dropout and picture breakup on digital TV's. Does this apply to the audio signal going to the HomePlugged SqueezeBoxes/Transporters as well?
I did a quick search of some AV forums last night and the net outcome seemed to be that these devices are a last resort (after running ethernet cable or using Wireless N). Most people who tried these devices were unable to stream 1080i video without stuttering, especially if the devices were not on the same powerline spur. Although the software utility suggested a good connection, the measured data throughput was often terrible, worse than wireless. Some people even had terrible throughput when using the devices in the same room, getting 1mbps instead of 100mbps (let alone the advertised 200mbps). I was really hoping to avoid sliding along on my stomach in the roof space, over the fibreglass insulation to run cable. I can just see myself putting a knee through the plaster However, looks like it is the only guaranteed way of getting a good throughput.
