Neo 3pdr and neo 8 combo
0 Members and 1 Guest are viewing this topic. Read 1444 times.
Stuart
« on: 11 Feb 2009, 07:54 pm »
Hi everyone,
I would like to know has any one tried the neo3 pdr and neo 8 together as a tweeter-midrange combination, also what would be better, the neo 8 or neo 8pdr in this aplication. Has anyone have any ideas???
Stuart
Danny Richie
Re: Neo 3pdr and neo 8 combo
« Reply #1 on: 11 Feb 2009, 11:11 pm »
A single Neo 8 can be crossed as low as 1kHz. The Neo 3 pdr can be crossed as low as 1.5kHz. I typically cross it at 1.8kHz.
Going to the 8 as a mid just doesn't make a lot of sense to me when you can cross the 3 as low as that. Really what would you let the 8 cover 1kHz to 2kHz? It's too small of a range.
Stuart
« Reply #2 on: 12 Feb 2009, 04:37 am »
Hi Danny,
The woofer i want to use is only really good up to about 800, but fantastic from there down, I was thinking of using the 8 as a mid from 800 to about 3.5 and use the neo 3 as a good tweeter. The ones that you sent me sound really sweet up the top end of the specrum and i dont know of another tweet that sounds that open and clean for the price, so its essentially a three way that i want to build for this woofer. What do you think?
Stuart
Danny Richie
« Reply #3 on: 12 Feb 2009, 05:00 am »
It could work.
