Bryston 8B STbTHX
0 Members and 1 Guest are viewing this topic. Read 4891 times.
bkm
Bryston 8B STbTHX
« on: 10 Feb 2009, 07:08 pm »
Any body using 8B ST (THX)for stereo music? How do u rate this amp? It is available used (1995 make)for about 1200 $? Whether the sound can be said to be good enough to justify buying a used one? How is its performance in bridged manner ? I intend to use it with bookshelf,like Quad 11L speakers.
bkm
Re: Bryston 8B STbTHX
« Reply #1 on: 14 Feb 2009, 07:28 pm »
James , I would expect some response from you .
jethro
« Reply #2 on: 14 Feb 2009, 09:21 pm »
bkm,
The 8B-ST is an excellent amp - I own an 8B-ST-Pro. I believe it would be a
good match with your speakers based on it's power output and the price of
your speakers. The SST amps are better in my opinion but I used an 8B-ST
for several years to listen to music. Each channel of the 8B-ST has enough power to
drive you quads, but if you want to experiment I would try bi-amping instead
of bridging.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 14 Feb 2009, 10:39 pm »
Hi bkm,
Sorry I did not realize you were asking me specifically about the 8B - I thought you were asking the group for opinions.  Anyway I'm as biased as they get so yes the 8B is a great amp and in fact in bridged mode actually has less distortion than in normal 4 channel mode.
Obviously it will not sound as good as the current SST Squared models but depending on where and how your using it; it should sound very good indeed.
james
« Last Edit: 15 Feb 2009, 02:43 am by James Tanner »
ncaahockeyfan
« Reply #4 on: 20 Jul 2018, 08:06 pm »
James,
I have been shopping for a used 4b-st, but have come across a deal  on a used 8b-st. How would an 8b-st bridged perform compared to a 4b-st. Thanks!
« Reply #5 on: 20 Jul 2018, 08:29 pm »
James,
Hi
The 4B would be able to deliver more current into lower impedance. We usually do not recommend bridging a Stereo amplifier into any load below 8 ohms.
James
