Quote from: Jon L on 2 Mar 2009, 08:05 pmI would only consider a preamp in your case if your system needed extra "kick" and drive in the bass, in which case Pass B-1 buffered preamp may be added to your list. I just received a B-1 the other day to use between my MW Transporter and my Spectron amp. It definitely seems to add more kick and so far I'm happy with it. I have a pair of EVS Ultimate Attenuators that you could use in your particular situation, though they're not remote-controlled if thats an issue.
Also, since the output of your DAC is analog, then you do have an analog source. You are more in the analog domain than you care to think.
It's gonna be hard to find a transparent line stage for under a grand.
Ed,I found that my Havana directly into the Carina was really nice, and that's the same 800 ohms into 100k as your setup, but I've got another Minimax preamp on the way -- should arrive today, in fact, so when I get my Carina back, I can let you know how that works out.I actually got the preamp because I want to build a modified version of Poindexter's Musical Machine using 6sn7s as drivers and I will need a preamp for that setup. Not replacing the Carina, btw, just want a low power, super sweet PP amp to try with the various speakers I have.-- Jim
Ed,Agreed, it's for another thread, but I'll just say that I'm doing a total makeover of my Horns and I will be glad to share my before and after results with you.Have you considered a simple, one-in, one-out aikido?-- Jim
