0 Members and 1 Guest are viewing this topic. Read 10971 times.
I am currently running my Havana DAC into a F5 clone. The Havana DAC has a 2.6V output and <800 ohm output impedance. The F5 has 100K input impedance. I currently use the digital volume control through the USB connection but I would like to leave that at 100% and control volume through an analog control.There is a Decware ZSLA-1 tube buffer stage preamplifier for sale near me so I am considering trying it out. Best,Ed
Which "digital volume control" do you use in which software? They are not all created equal, but the good ones will degrade the sound much less than your average volume pots or active preamps, unless you are attenuating massively. I doubt that b/c F5 is a low-gain amp. Personally, if your system sounds good now, I would avoid it like the plague to add any additional "stuff."
Thanks for the replies guys. I am now debating whether or not to add another link in the chain. Gain; I probably need more headroom (which I realize the buffer will not offer) but the amp will play as loud as I typicaly listen. Of course some albums are louder than others so some could use a bit more gain. I appreciated the simple signal chain, I am getting a nice clean sound although not dry or sterile. I dont want to add any noise to the system or degrade the sound so I would probably be looking a a fairly expensive (to me) preamp.Quote from: Jon L on 28 Feb 2009, 02:15 amWhich "digital volume control" do you use in which software? They are not all created equal, but the good ones will degrade the sound much less than your average volume pots or active preamps, unless you are attenuating massively. I doubt that b/c F5 is a low-gain amp. Personally, if your system sounds good now, I would avoid it like the plague to add any additional "stuff." JonL, I agree, I don't want to add any unecessary complexity to the system. I am playing FLAC files via Foobar2000 with Xlobby as the UI, works very nicely with the thin client (iPaq PDA) acting as a remote with coverart and easy playlist generation. How does Foobar's volume control stack up? I have Xlobby set up for .5dB increments and rarely have to attenuate more than a few dB.Best,Ed
I would only consider a preamp in your case if your system needed extra "kick" and drive in the bass, in which case Pass B-1 buffered preamp may be added to your list.
Quote from: ebag4 on 2 Mar 2009, 07:05 pm debating whether or not to add another link in the chain. What about taking out a link? Every time you have to change, recalculate, or transfer the digital signal you have just taken a non repairable step away from the original music. The less calculating and manipulation that you do in the digital domain the better. I know I'm in the minority on this one because once you are in the digital domain, you are supposed to be free to do whatever you want without consequence. I think that's where all of the real damage is done.Some day you might want to hook a component up that has analog outputs. It's nice to be able to do that too.
Quote from: Jon L on 2 Mar 2009, 08:05 pmI would only consider a preamp in your case if your system needed extra "kick" and drive in the bass, in which case Pass B-1 buffered preamp may be added to your list. I just received a B-1 the other day to use between my MW Transporter and my Spectron amp. It definitely seems to add more kick and so far I'm happy with it. I have a pair of EVS Ultimate Attenuators that you could use in your particular situation, though they're not remote-controlled if thats an issue.
The B-1 does not have any gain, so I'm attributing all the additional "kick" to the low output impedance of the buffer, which I'm guessing is substantially lower (B1's is 2000ohms) than the output impedance of the MW Transporter (Dan hasn't measured specs on this yet I believe). In your case I was surprised at how low the output impedance of your DAC was and yeah I agree, it wouldn't seem that you would benefit in any way from a buffer like the B-1, but, if you are interested in trying it it would basically give you what you're looking for (a transparent volume control) and perhaps even add some more dynamics to your music (who knows?), in addition to giving you a channel balance control, which for me was important to have in my room as the image leans heavily to the right. Mark at Reno HiFi is great to deal with and is offering an introductory price on the B-1 as well as a 30 day satisfaction guarantee. In the end, there's only one way to find out I guess. One thing to consider as far as my remedial understanding of all this goes is that the B-1 has the 2000ohm output impedance and delivers that throughout the audible frequency range; though your DAC's output impedance is measured as 800ohms or so, that could only be at a particular frequency unless its specified by the manufacturer, so who knows, there may be some gains to be had by putting a buffer in between it and your amp.
In my system my amp is of low enough gain (F5 Clone) that I attenuate very little to reach my normal listening SPL, of course the flip side of that is that I have very little headroom left from my amp.
