Quote from: rydenfan on 9 Feb 2009, 06:58 pmQuote from: targa on 9 Feb 2009, 03:33 amThe one speaker that I have not owned nor auditioned is ATC.. Any one has experience with that? I know Ted did and has talked to him at length.. I am very curious about ATC (accurate, transparent, dynamic?)Who cares? With the way you describe your speakers why even think about another speaker??? Just sit back and enjoy the music Geesh!!! Why do you continue to exhibit rudeness towards fellow members? Maybe you should take your own advise and "Just sit back and enjoy the music". Cheers,Robin
Robin,Are you stalking Rydenfan? What gives? This is like the third or fourth thread in a row that you've slapped him on. I told Lance the same thing (i.e now that you've found the loves of your life, the Timepiece 3.0's, let go of the ATC idea and enjoy)...doesn't seem to be a rude idea at all!
Quote from: satfrat on 9 Feb 2009, 07:21 pmQuote from: rydenfan on 9 Feb 2009, 06:58 pmQuote from: targa on 9 Feb 2009, 03:33 amThe one speaker that I have not owned nor auditioned is ATC.. Any one has experience with that? I know Ted did and has talked to him at length.. I am very curious about ATC (accurate, transparent, dynamic?)Who cares? With the way you describe your speakers why even think about another speaker??? Just sit back and enjoy the music Geesh!!! Why do you continue to exhibit rudeness towards fellow members? Maybe you should take your own advise and "Just sit back and enjoy the music". Cheers,RobinRobin, I wasnt being rude in the least. I leave that duty for you. BTW, I dont see you listed anywhere on this forum as a facilitator so what gives with you thinking you can police everything?I just know it can be easy in this hobby to drive yourself crazy thinking of other things and was trying to help with a little friendly perspective.
Jim, yes. i do recognize the intention absolutely and thank you, Robin! i am the new kid on the block here and appreciate your and other support.. i did not mean to ignore that at all..
Just a thought Lance but I've found that bad floor noise (ground noise) can also come from a lack of good power conditioning, especially when using high effeciency loudspeakers. The more you can lower that ground noise, the less of that high frequency "nasties" will show itself that often causes listeners fatigue. If you can get your hands on a different form of power conditioning than what you now have, just to try out like possibly Running Springs, BPT,,etc, it may be worth the effort.Cheers,Robin
Quote from: satfrat on 14 Feb 2009, 02:38 amJust a thought Lance but I've found that bad floor noise (ground noise) can also come from a lack of good power conditioning, especially when using high effeciency loudspeakers. The more you can lower that ground noise, the less of that high frequency "nasties" will show itself that often causes listeners fatigue. If you can get your hands on a different form of power conditioning than what you now have, just to try out like possibly Running Springs, BPT,,etc, it may be worth the effort.Cheers,RobinRobin,It wasn't his noise floor, it was his friends megasystem; as he said, likely due to the super hi-efficiency horns and not enough attention to that side of the detail. Classic horn issue. His is fine.
Hay Lance, you in Houston? I'm going to the Houston Audio Society meet this morning...If you live in the Houston area you got a bunch of new friends.
