0 Members and 1 Guest are viewing this topic. Read 40712 times.
good fellows, thank you for the recommendations... i will add more for sure...the room acoustics is a bit odd... for example, if i use the certains behind the TV and cover the TV up, i hear a clear change in the soundstage and (more) details. also, yesterday i was testing out a new power conditioner and put it on the left side behind the TV, covering up that area a bit, the center image was then pulled over to the left... when i removed that conditioner, the imaged was centered again... so the front walls - behind the speakers - do have a significant impact of overall room acoustics...I will also try the SP Tech on more powerful amps with Jim... main concern is that i may like that sound better... more later. thanks for the inputs...
..one detail about SP Tech - that i was not looking for before - got my attention was their ability to play very loud w/o blowing up or losing accuracy.. i have no need for playing loud but i know that none of my past speakers can do this well..
good fellows, thank you for the feedback. i will look into EightNerve Adapt products. i will also try to make it to the tomorrow meeting... i heard that Merlins speakers are excellent. i almost put in the order for the Merlins speakers over a year ago. i talked to the designer (forgot his name...) for hours but finally decided not to... no particular reason why... i think because i did not really know what "sound" i wanted... and honestly, i did not know what accurate speakers would sound like... i have been disappointed with all my past speakers in that they can not resolve complex pieces of music. this prompted me to search for transparent/ high resolution speakers and i read about ATC speakers. I consistently read about their high resolution capability in reviews... and this high resolution was often attributed their accuracy and that was how i was looking for accurate speakers. now how i ended up with SP Tech is another (good) story and just by luck... anyway, needless to say is that the market has many great speakers with different design principles. even if their goals are the same, different design principles (with their own compromises) lead to different outcome. one detail about SP Tech - that i was not looking for before - got my attention was their ability to play very loud w/o blowing up or losing accuracy.. i have no need for playing loud but i know that none of my past speakers can do this well.. more later... sorry need to finish up something...
btw - i am not too happy with the anti-cables...
Yes, the SP Tech waveguide loves to be heard straight on (meaning pointed at each ear), and with its dispersion pattern the beaming is not an issue. I have my Revs that way. I think that this somewhat severe-for-the-faint-of-heart toe-in creates image specificity that is quite extraordinary, but doesn't lose soundstage width (ok, maybe a few degrees). I'm glad your coming along, Lance. I have little input on NOS vs OS DACs other than to say the DAC in the Modwright Transporter is very good; the new Weiss Minerva firewire DAC is incredible, and good things are being said about the Bryston and the Berkeley.
