What size Parts Express box for a MTM?
0 Members and 1 Guest are viewing this topic. Read 5834 times.
HT cOz
« on: 4 Feb 2009, 03:35 am »
What is the best size PE box for an A/V-3 Neo?  .75 or 1.0?  I assume it would be sealed.
Robert
Sonny
Re: What size Parts Express box for a MTM?
« Reply #1 on: 4 Feb 2009, 04:04 am »
PM sent
S Clark
« Reply #2 on: 4 Feb 2009, 05:11 am »
I am pretty sure that the AV3 Neo version is still a transmission line speaker.  PE does not sell an equivalent box.
HT cOz
« Reply #3 on: 4 Feb 2009, 01:32 pm »
You are correct.  I should have said the A/V-3 Neo Center.  I am looking at the PE Curved boxes for a center channel.  So what would the better volume be .75 or 1.0?
Robert
HT cOz
« Reply #4 on: 4 Feb 2009, 04:37 pm »
If I've done my math right, it seems Danny's AV3 Center box is .75 or very close.  So if using a PE Curved box with the known problems of overstating volume would the .75 or 1.0 be the better choice?
Danny Richie
« Reply #5 on: 4 Feb 2009, 04:51 pm »
Actually the sealed box version is about .55 cubic feet.
The second thing to look for in a box is keeping the frontal area down to a minimum. The designed front baffle is 18.75" by 8". I would stray too far from that.
HT cOz
« Reply #6 on: 4 Feb 2009, 05:13 pm »
I've looked up the PE baffle the .75cf is 17" by 10" and the 1.0cf is 22" by 9".  Are these so different that using them would be an issue?
Sorry for all the questions, but I don't want to waste my money when the real solution is to build my own or contract someone to do it for me.
Robert
BrianH
« Reply #7 on: 4 Feb 2009, 05:22 pm »
When I looked at PE cabinets I noticed that there often were two versions, one called MTM with a narrower front and a TWC with a little wider front.
TWC is 10" and the MTM is 8" for the .75 curved sides.  Looking at the box plans it would seem the 8" would work assuming 8" is better sonically than 10". Certainly its closer to Dannys designed box.
Just some thoughts. For whatever they are worth.
Hank
« Reply #8 on: 4 Feb 2009, 06:11 pm »
Also, keep in mind that Danny determined that the PE cabinets were actually smaller volume than advertised, so it was then best to use their 1 ft^3 cabinet when a design called for a .75 ft^3 cabinet.  I think I remember that PE finally acknowledged the problem and was going to instruct their supplier to increase internal volume - don't know if that's been done yet.
Guys, am I remembering this correctly?
HT cOz
« Reply #9 on: 4 Feb 2009, 06:35 pm »
I double checked which cabinets I was looking at and must not have looked at the correct box before.  These are the baffle sizes:
MTM .75cf = 8" by 20"
MTM 1.0cf = 9" by 22"
Robert
Danny Richie
« Reply #10 on: 4 Feb 2009, 06:41 pm »
It was the curved boxes that had less volume than advertised.
These are pretty easy boxes to build. So what you do is say, hey Hank! How much to build me one of these?
Nick77
« Reply #11 on: 4 Feb 2009, 07:13 pm »
Danny is the av/3s revision with Neo3 ready to go?
Danny Richie
« Reply #12 on: 4 Feb 2009, 10:59 pm »
It will be shortly. I am just waiting on some enclosures to arrive so that I can get the network designed. This is one of two pairs that were recently built. I await the arrival of the other pair.
HT cOz
« Reply #13 on: 5 Feb 2009, 01:46 am »
Wow those are sweet!   :drool:
dvenardos
« Reply #14 on: 5 Feb 2009, 06:14 pm »
Do those have side loaded woofers? The cabinets are HUGE. :)
EARGASM
  • No thanks.
« Reply #15 on: 9 Feb 2009, 05:09 pm »
Removed by member.
« Last Edit: 25 Sep 2009, 04:08 pm by EARGASM »
dvenardos
« Reply #16 on: 9 Feb 2009, 07:30 pm »
BTW, is anyone interested in the [sealed] MTM or Neo 2X in a tower with a side firing servo sub? I think it's a solution to my placement issues, but was just wondering what you guys thought? Thinking of a design using a "bass base."
 :dance:
HT cOz
« Reply #17 on: 9 Feb 2009, 07:50 pm »
Thank you, cOz.
They are TL's like the AV3. The terminus is in the back. They can be front terminated as well. The second pair is prettier... 8)
Eric
The cool thing is that I think a sealed setup with sub might end up being smaller.
Danny Richie
« Reply #18 on: 9 Feb 2009, 08:01 pm »
Actually the N3 is about 1.4 cubic feet of air space.
Sealed will require .5 cubic feet.
A sealed Neo-2X requires .5 cubic feet.
The SW-12-04 needs 1.5 cubic feet.
So with either of them up top plus a single servo sub will be about 2 cubic feet of air space. That lower section surrounding the sub will need to get pretty beefy too so it may appear slightly larger.
EARGASM
  • No thanks.
« Reply #19 on: 9 Feb 2009, 09:42 pm »
Removed by member.
