Master Set Speaker Placement
stvnharr
Re: Master Set Speaker Placement
« Reply #20 on: 6 Feb 2009, 08:01 am »
Steve your explanation of the Master Setup has helped me find the proper position of my speakers. I was very close but the right channel was weak. I am now coupled by moving the right speaker back just a few inches, that little move was the missing piece for full range sound in every listening position. Another big thank you for your easy to understand explanation of this must do procedure. Please all dont pass up this setup for the best sound possible from your speakers and system a little bit of time and effort is well worth it.
FABULOUS!!!!!
I'm really glad I was able to help make it all happen!!!
This is the best kept secret in ALL of audio.
I think EVERYONE can benefit from this!
You can also play music louder, have it sound better, and nearly have the band in the room with you - NO EXCEPTIONS!!!
