0 Members and 1 Guest are viewing this topic. Read 46783 times.
Just tried the new 7.4 beta and I hear some improvements. I have been good about upgrading and listening to all the new software (and firmware) with my SB3, usually with very little or no improvement in overall sound quality--though the features have improved. Today I tried the 7.4 beta because in the notes it says WAV files are now played as PWM (it used to say WAV to WAV native --no transcoding). Well, I hear sound that is more natural with cleaner space and better timing. The frequency balance and tonality are unchanged, but it has a certain immediacy and correctness (Is that a word?) that it lacked previously. Similar to modding a DAC with a Superclock. Anyone else tried it that can confirm, deny or comment?Chris H.
I just tried it as well. I get better focus of images and each sound is more specific to itself in tonality and location.
Yep, using FLAC. No change in any settings, just ran the 7.4 executable.
Quote from: Tyson on 29 Jan 2009, 12:50 amYep, using FLAC. No change in any settings, just ran the 7.4 executable.So I assume you transcode/convert to WAV (now PCM) in SC, as opposed to sending FLAC -> FLAC all the way to the player? (cuz there was no change in the FLAC decoder from 7.x to 7.4).
Quote from: ted_b on 29 Jan 2009, 02:21 amQuote from: Tyson on 29 Jan 2009, 12:50 amYep, using FLAC. No change in any settings, just ran the 7.4 executable.So I assume you transcode/convert to WAV (now PCM) in SC, as opposed to sending FLAC -> FLAC all the way to the player? (cuz there was no change in the FLAC decoder from 7.x to 7.4).Ok, I want to be sure I am using the best settings...When I look in the settings at the advanced tab and select file type, I see the following for FLAC:File Format Stream Format DecoderFLAC FLAC Native or Disabled (only options possible)FLAC MP3 Disabled (grayed out - no options possible)FLAC WAV FLAC or Disabled (only options possible)What should be selected for optimal playback of FLAC files?I currently have Native and FLAC as my selections for the FLAC and WAV stream formats respectively.Thanks,George
So I solved my problem by converting the 24/96 files to Wavpack (keeps the tags, etc. rather than going WAV) and then it uses it's own PCM decoder further down the list. Voila. I like the new 7.4 PCM sound.
