0 Members and 1 Guest are viewing this topic. Read 6984 times.
is the "s" exaggerated during playback, or would you describe the upper midrange having a hard and metallic sound to it? if it's the former you need to upgrade the avr, if it's the latters you need to soften the sound with a tubed dac or something. it seems like you may have not had much experience with tubes...if this is the case an inexpensive tubed dac (mhdt, cal labs, scott nixon, etc) will go a long way towards fixing the stridency you describe. there's a reason a lot of music lovers (and audiophiles!) can't live without tubes. happy hunting .
Quote from: JP78 on 24 Apr 2009, 09:11 pmis the "s" exaggerated during playback, or would you describe the upper midrange having a hard and metallic sound to it? if it's the former you need to upgrade the avr, if it's the latters you need to soften the sound with a tubed dac or something. it seems like you may have not had much experience with tubes...if this is the case an inexpensive tubed dac (mhdt, cal labs, scott nixon, etc) will go a long way towards fixing the stridency you describe. there's a reason a lot of music lovers (and audiophiles!) can't live without tubes. happy hunting .If you had read the entire thread you would already know I've tried an integrated amp with them. It was solid state, class A.
Quote from: kip_ on 24 Apr 2009, 09:16 pmQuote from: JP78 on 24 Apr 2009, 09:11 pmis the "s" exaggerated during playback, or would you describe the upper midrange having a hard and metallic sound to it? if it's the former you need to upgrade the avr, if it's the latters you need to soften the sound with a tubed dac or something. it seems like you may have not had much experience with tubes...if this is the case an inexpensive tubed dac (mhdt, cal labs, scott nixon, etc) will go a long way towards fixing the stridency you describe. there's a reason a lot of music lovers (and audiophiles!) can't live without tubes. happy hunting .If you had read the entire thread you would already know I've tried an integrated amp with them. It was solid state, class A.JP78 didn't say anything about integrated solid state class A, he said try some tubes with these speakers. I prefer the sound of my Selah speakers without my tubes and my partner prefers them with tubes, specifically a Nixon TubeDac+. Adding tubes to your system in one form or another may very well remedy this problem.
Okay, I tried an integrated amp with them and cut my receiver's preamp and amp out of the loop. I still heard it to a lesser degree. I don't think what I'm hearing is sibilance per se I just think the upper end of the vocals could be a little less harsh and more natural. I definitely don't hear this in the highs. If I play with the "treble" trim on my receiver this does nothing so I think the problem is in the upper midrange.
....is the "s" exaggerated during playback, or would you describe the upper midrange having a hard and metallic sound to it? if it's the former you need to upgrade the avr, if it's the latter you need to soften the sound with a tubed dac or something.
He said I needed to upgrade the AVR
