0 Members and 1 Guest are viewing this topic. Read 10090 times.
I'm listening to it now and it's as good as I've heard the RM40's. Of course this is "my" preference, which is for a strong bass and midbass, a slightly warm sound, and very smooth mids/highs (in that order). The DCX gives a lot of power and flexibility to tailor things how you like, I hope some others out there find these posts somewhat useful.
I tried the 1.9 khz setting with a q of 1 and it's quite nice, I'm keeping it there.I also lowered my tweeter crossover to 2.5 khz, and raised the bass crossover to 650hz w/a 12db L-R slope - this is even better than the 500 hz crossover. I tried higher points, just as 700 or 750 hz, but it started to sound like crap w/that high of a crossover, likely due to cancellation issues, but regardless 650 hz is as high as I can go in my room and still get good coherent sound.
Oh, it gets better - I have the very last of the mgalusa modded DCX's and mine is quite different from the previous one's he did - basically it was optimized to be a crossover only and all the volume control and preamp functions were stripped out. It's a lot cleaner and more focused than the standard modded DCX, and I'm very, very happy with it. But, these things are a LOT of work, and he's stopped offering mods to anyone on them. I was the last in line and I'm quite happy with my ultra-custom DCX.
So what type of mod is in yours now? Is it still based on the Jan Didden/ Selectronics output board with some of the functions bypassed or is it more like the direct out mod? Did you change the AK4393 dac chips to AK4395 or 96 yet?
How about fun with a DEQ. All of the fine tuning by ear that you are doing would be much more intuitive and offer finer control with a graphic EQ in front of the DCX. You may also enjoy a little dynamic expansion and stereo widening as well. I know that the analog in, (and digital in) of your DCX has been modded so a new DEQ2496 might not sound quite as good with the analog in but maybe you can get someone (wink) to mod it as well. Or, all of this Behringer 2496 gear is very tranparent if you can get to a point where you can run digital in..http://www.zzounds.com/item--BEHDEQ2496
Quote from: sendler on 18 Mar 2009, 11:03 amHas anyone had any success with or know of a REALLY GOOD modification to the DEQ2496? Paul
Quote from: PLMONROE on 18 Mar 2009, 01:06 pmQuote from: sendler on 18 Mar 2009, 11:03 amHas anyone had any success with or know of a REALLY GOOD modification to the DEQ2496? Paul.You don't need to mod the DEQ if you have a modified DCX. Just use it in front of the DCX's digital input. The DCX's analog output will still sound like it did. There may be a slight difference in the sound of the analog in of the DEQ compared to the analog in of the modified DCX if you use that, but running a DEQ digital out should be pretty transparent. As for mods, I like the direct out mod for it's simplicity and sonics.
Use of the digital out of the DEQ into the DCX will still use the DCX's mods that you like for the outputs. No harm in trying it to and see if the analog conversion of the modified DCX is that much better than the DEQ.
I use a Behringer DEQ2496 between my CD Transport and DAC, so in digital only. Most commentators say that is the best way.Brian said that the ADC/DAC in the DCX2496 was neutral so that the subtleties of a CD's DAC would be revealed. I presume that means that if I were to use an SDE VMPS speaker at the end of my system, the quality of my DAC would still shine through even though there are two more signal conversions in the chain.For me anyway, if I was going to spend $2,000 on mods to a Behringer DCX or DEQ, I would also consider the DEQX or Tact which as far as I can see offer EQ and cross overs in one box.
As to the DEQX, I see those for sale used on audiogon and read comments about poor sonics. It seems that may be one of those products that measures well but sounds blah.
