0 Members and 1 Guest are viewing this topic. Read 14410 times.
In the discussion you linked, you seem to be defining it as "ANY case where acoustic interference causes a deep null (we can define "deep" separately)."
A subwoofer with its phase set incorrectly creates standing waves with the main speakers.
Do these apply to comb filter effects?
you're arguing that virtually all room acoustics are standing waves, with the possible exception of the direct signal from the loudspeakers, and if they're not exactly equidistant from the listener, then these are also standing waves, as well.
most of what you refer to as non-modal "standing waves" in the bass region are so varied in frequency and level that they end up smoothing out so that they are not a concern in the bass region in typical room acoustics.
Quote from: youngho on 21 Jan 2009, 07:46 pmIn the discussion you linked, you seem to be defining it as "ANY case where acoustic interference causes a deep null (we can define "deep" separately)."Actually the waves stand still at peak locations, but I know what you mean.
QuoteDo these apply to comb filter effects?Yes. Again, if "standing wave" means the wave is standing and not traveling, then the cause is irrelevant, no?Quoteyou're arguing that virtually all room acoustics are standing waves, with the possible exception of the direct signal from the loudspeakers, and if they're not exactly equidistant from the listener, then these are also standing waves, as well.No, peaks and nulls caused only by different arrival times are not due to standing waves. In that case the waves from both directions are traveling.
ALL cancellations are caused by waves arriving at your ear at the same time from different directions and/or out of phase. Comb filtering is no difference. SBIR is simply another form of comb filtering. Yes - particles are moving back and forth and not truly travelling - however, the 'wave' does move. One can have standing waves and travelling waves. The travelling waves absolutely move in space. This is easily seen in an untreated room by looking at waterfall plots with a very long time window.
A standing wave doesn't literally stand still when it comes to sound. The woofer still moves back and forth
If a sound wave literally stands still, how can it be sound? How can it have a frequency and wavelength? How can it travel at the speed of sound?
Aren't the peaks and nulls of comb filter effects are caused by different arrival times?
As for modal ringing, the extent to which this really occurs is controversial. Much of the long decay time is actually due to the high amplitude to start with, even if it's not truly a minimum phase phenomena. We've been through this before.
A standing wave has two effects: constructive interference and destructive interference. I've said this all along.Comb filtering has two effects: constructive interference and destructive interference. No argument there.Just because two things are composed of the same components do not mean that they are the same thing. White light and a refraction spectrum/rainbow are not the same thing, even though they might contain all the same wavelengths of light. Just because two things can produce the same effect does not mean that they are the same thing. A pistol and a revolver are not the same thing, even though they both produce a bullet travelling at high velocity.Adding a second speaker results in constructive interference. If it's not exactly equidistant, it will result in a pattern of constructive and destructive interference. This frequency response pattern is a comb filter. It is not a standing wave. How is a single loudspeaker reflection modelled in psychoacoustic experiments? By a second loudspeaker. Specular ray-tracing models are used to show where the virtual speaker would be from a single reflection, and then if the wall is eliminated, an actual second speaker can be placed in the location of the virtual speaker. By controlling the loudness of the second speaker, you can examine things like the audibility of single reflection at various levels. Ethan drew a distinction between a reflection versus a second loudspeaker interacting with the original source. In fact, they are essentially the same phenomena. The thing is, in most typical listening rooms, there is more than a single reflection because there is more than one wall or boundary. Most rooms have six or more. Plus windows, doorways, and HVAC complicate things in the bass region. Most people listen to two or more loudspeakers. If the room and loudspeaker setup are not EXACTLY symmetric, then you'll have another set of reflections and interference patterns to hear.A 5 Hz wide null in the low bass region has a VERY different Q than a a 5 Hz in the midrange, so you're comparing nulls of different width, but you're right, narrow interference dips should be less noticeable than wide interference dips of a similar amplitude.
I probably did say null in that discussion but I was wrong. Eric Desart explained (later) that I had the polarity reversed in my thinking. The waves collide at a peak location, defined as a point where the pressure is maximum. So two positive-going waves arriving from opposite directions doubles the pressure (6 dB peak), and that's the point where the waves stand still.
Sure, the speaker is moving, but that's not the location in the room where the waves are standing still. Even in the case of a resonant standing wave (which you recognize as a standing wave) the speaker is still moving air!
There is sound because the pressure rises and falls. But there's no wave movement at the point. Or something like that. I admit I'm not a physicist.
Yes, but it depends on whether the waves arrive from opposite or similar directions. When you sit two feet in front of a wall, with the speakers in front of you, reflections off the rear wall behind you come at your ears from a direction opposite that of the waves from the speaker. But when you hear mono music from two stereo speakers, and you're pretty far back from both speakers, the waves can arrive at different times but not be traveling in opposite directions. Do you see the distinction? In both cases you get peaks and nulls because there are two arrival times, but the waves stand still only in the first example of the rear wall. This aspect too was discussed in depth a few years ago, though I forget where. It might have been in the Sound On Sound magazine forum.
QuoteAs for modal ringing, the extent to which this really occurs is controversial. Much of the long decay time is actually due to the high amplitude to start with, even if it's not truly a minimum phase phenomena. We've been through this before.QuoteI'm not aware it's controversial! The extended decay is due to conservation of energy, no? If the walls had no losses the sound would continue forever.
