0 Members and 1 Guest are viewing this topic. Read 13250 times.
Quote from: Wayne1 on 13 Jan 2009, 03:33 pmI just installed this and my very few 24/96 files now play just fine and sound very, very good!Give it a try and let the rest of us know what you think.Link to SqueezeCenter 7.3.2 betaSorry for the ignorance, but which of >THESE< eleven files are you downloading?I'm needing just a little "101" on how to get the 7.3.2 beta software as opposed to doing the automatic way SC wants me to, which is the 7.3.1. version.Thanks fellas,Bob
There is now the choice of a 7.4 also, would one want to choose the higher number? Thanks
Download the .EXE file and run it on your pc. The software will take care of the rest.
This will work with the SB2, SB3, SBR and TransporterIt downsamples the 24/96 files to 24/48.The SB software has always been able to play 24 bit.The Transporter has a larger buffer so it can natively play 24/96
I have downloaded 7.3.2 but am unable to play 24/96 WAV files on my SB3.Chris H.
Quote from: rydenfan on 13 Jan 2009, 09:21 pmQuote from: zybar on 13 Jan 2009, 09:00 pmQuote from: woodsyi on 13 Jan 2009, 08:21 pmI heard the stock. I have a modded one and couldn't be happier!! +1 +1 +1
I heard the stock.
Quote from: ted_b on 15 Jan 2009, 04:30 amQuote from: rydenfan on 13 Jan 2009, 09:21 pmQuote from: zybar on 13 Jan 2009, 09:00 pmQuote from: woodsyi on 13 Jan 2009, 08:21 pmI heard the stock. I have a modded one and couldn't be happier!! +1 +1 +1 + whatever
