Squeezebox Duet Remote Question
0 Members and 1 Guest are viewing this topic. Read 1241 times.
dthoms
  • Dee Thoms
« on: 7 Jan 2009, 11:27 am »
Can this remote dual as a universal volume control for other components?
mcgsxr
Re: Squeezebox Duet Remote Question
« Reply #1 on: 7 Jan 2009, 01:28 pm »
I don't own one, but would doubt it, as I believe it is strictly a wifi remote, not an IR remote.
I am sure someone who owns one will chime in.
PhilNYC
« Reply #2 on: 7 Jan 2009, 01:29 pm »
No, it only works with Slim Devices products.  It controls things via a wireless network connection (rather than infrared), so there isn't a way for it to communicate with something that isn't on the network...
MerlinWerks
« Reply #3 on: 7 Jan 2009, 06:18 pm »
Actually the Duet controller does have an IR emitter built in, it is off by default, but can be turned on (deep in a test menu) and I believe will control existing SB1/2/3 devices via IR. I got the impression that it's future implementation will be a SqueezeBox community development project. Search the SlimDevices forums to see if there has been any progress.
