0 Members and 1 Guest are viewing this topic. Read 26136 times.
Most people have pretty OK power, especially if don't live in a high density metropolitan area. So, PC's and conditioners will have a lesser effect. I, however, am one of those people that live in the heart of a downtown area. For me, good conditioners have a dramatic affect, while average or poor conditioners have no effect at all (or worse, a detrimental effect). For most people, I'd say get the majority of the system sounding the way you want it via component and speaker selection, speaker wire, and interconnects. Focus on power last, as a final refinement. For a few people (like me), power is so bad that it really needs to be addressed up front before you can really hear how good the rest of your gear is.
Something else I have noticed while searching for a conditioner, is that the price rises significantly as you add more outlets to the unit, while all other specs seem to stay the same. Does it make sense to buy a simple dual outlet conditioner and plug a power strip into it (I think this is what Robin mentioned) to extend the amount of output plugs? Would there be any adverse effects to that, most seem to have a 15amp (or 20amp) breaker no matter the number of outlets.
The majority of the time people are looking for a power cord, or any cord for that matter, that will color, taint, do subjectively good things that are objectively bad, to fit their system. They are trying to fix a problem with another problem.
They are not aware that is what they want. They are just consumers that purchase different things to try, no reasoning behind it, maybe a Stereophile review... I do believe some cables are extremely important for quality, at least with digital and the mayhem behind it.
Um but you are not trying to keep the signals other than 60hz in-tact in the AC power. Filtering makes since because it has no affect on removing the 60hz which you do not even need per-say, you only need the right voltage and current, and besides that it gets converted to DC. There is no "integrity" to keep in-tact with AC unless you are loosing current or voltage to a point where it becomes a concern. The only thing you want to keep is the regular values and ability for dynamic changes on tap. It is not the same philosophy as interconnects in that respect . Once again this all has a LOT to do with your components of your stereo anyways.
Thank you all for your honesty, and candor. It is truly appreciated.I am open to a DIY conditioner. Actually, this might be somewhat desirable, because it would allow me to give it a form factor that would suit my needs better. I could (but would rather not) have something designed to fit in a rack. I've got a space thats about 6"x6"x24" that I would like to use for a power center, or a few inches of rack if need be. Though I am no electrical engineer, I managed to make a Jacob's ladder out of an old neon transformer... (very easy to do) but, I guess I would be trying to eliminate an arc rather than create one, huh? I'm not concerned about hurting myself, but I would hate to damage any of my equipment... If I can understand it, I can build it. But if there is something commercially available, and not too expensive... I will sleep better, if you know what I mean.I will get a Hubbell duplex for the wall, that makes a whole lot of sense. Regeneration? that sounds intriguing, got any links?Thanks again, so far you all have been very helpful.Cheers,Greg
Quote from: Destroyer of Smiles. on 2 Jan 2009, 05:59 amUm but you are not trying to keep the signals other than 60hz in-tact in the AC power. Filtering makes since because it has no affect on removing the 60hz which you do not even need per-say, you only need the right voltage and current, and besides that it gets converted to DC. There is no "integrity" to keep in-tact with AC unless you are loosing current or voltage to a point where it becomes a concern. The only thing you want to keep is the regular values and ability for dynamic changes on tap. It is not the same philosophy as interconnects in that respect . Once again this all has a LOT to do with your components of your stereo anyways.That's right! I forgot. There is no such thing as noisy DC.
