0 Members and 1 Guest are viewing this topic. Read 22730 times.
Modeling clay has been ordered.Chickens!
The speakers already use a compressible gasket to prevent air leaks.We're talking about adding mass to the spiders or basket of the speaker.
P.S. Note that adding mass properly is not always a bad idea. Years ago at the home of a group of audiophiles in Barbados, I was given an interesting A-B test of this idea with a big set of bookshelf speakers. The owner had made up a set of very heavy (about 40 pounds as I remember) concrete plates the size of the speaker tops. They were Naugahyde padded to avoid scratching the speakers and to provide a good contact. The difference between the speakers with the pads on top and with them removed was very obvious. Probably Newton's laws of motion at work again. You could here the sound change with your eyes closed as the were placed and removed during play.
I designed my speakers cabinets with a 1 inch thick steel plate (~40 lbs) to go between the top cabinet (containing the midrange and tweeter) and the woofer cabinet.
Can you post some pictures of that, just so I can see something I have never seen before. Espically interested in the rack, that sounds kind of neat.Rahimlee54
Good heavens. You look normal. How did you get into this thread?
Quote from: fsimms on 29 Jan 2009, 04:00 amQuoteI designed my speakers cabinets with a 1 inch thick steel plate (~40 lbs) to go between the top cabinet (containing the midrange and tweeter) and the woofer cabinet.That is a killer cabinet. It looks almost as good as Jim's!Bob
Thanks very much for running the tests Dennis.I can assure you that plastic modeling clay (available in 5 pound bricks at art stores) will not ever come loose or fall off of the speaker metal parts if properly installed in the first place. You can actually carefully heat it up in a microwave oven to make it very soft and workable.We have used this on the little Biro L/1 speakers we built for Mithat Konar for years without ever a field problem.The test I ran at B&W in Worthing, England years ago was a true double blind test. John Bowers gave me a matched set of their little CM-1 bookshelf speakers to play with in their lab. I had brought a half pound of plasticlay along with me when invited to a factory visit. I pulled the driver assembly from one and damped it thoroughly and then put it back together very privately. Since they had identical cabinets and no serial numbers yet, not even I could tell which one I had worked on.We set them side by side in their sound room and A-Bd them with mono material using the balance control of the drive preamp to switch from one to the other.The whole tour group got to listen. I asked everyone to write down the answer to two questions. First, can you hear any difference? Second is it a better worse difference and which one do you like better? After everone voted, I opened up one of the speakers again.The results, much to B&W's surprise, was that the damped speaker was by far preferred by nearly everyone.Again Dennis and or Jim, I urge you to try this on the midrange basket of a HT3 or Songtower. It is a very easy and inexpensive way to build a better speaker. The sonic result can most accurately be described as having stuff that was obvioulsy not supposed to be there go away, leaving more of the music, less garbage, and better sound.Best regards,Frank Van AlstineP.S. DO NOT TRY THIS WITH PLAYDO. THAT IS A FLOUR WATER PASTE AND SETS UP LIKE A ROCK AND IS USELESS FOR THIS PURPOSE.The scientific principal behind this proceedure is simple. Meatballs don't bounce.
Quote from: DMurphy on 29 Jan 2009, 03:53 amGood heavens. You look normal. How did you get into this thread?I can't be that normal, I put a steel plate in my speaker QuoteQuote from: fsimms on 29 Jan 2009, 04:00 amQuoteI designed my speakers cabinets with a 1 inch thick steel plate (~40 lbs) to go between the top cabinet (containing the midrange and tweeter) and the woofer cabinet.That is a killer cabinet. It looks almost as good as Jim's!BobThanks Bob. I haven't seen Jim's cabinets in person but from the pictures and the rave reviews, I believe that Jim's cabinets are a notch above mine. I'm not the most patient person so I went with automotive primer, paint and clear coat since you can put many coats on in a day. Jim hand rubs his finishes out with curing time between. The pictures of Jim's speakers look stunning and I understand that the pictures don't do them justice.Cheers,Tom
