DIY- RCA to male BALANCED
0 Members and 1 Guest are viewing this topic. Read 1620 times.
mclsound
« on: 28 Dec 2008, 10:07 pm »
i am adding a rca (from reciever pre-out) to male balanced for the input of Bryston 10blr.
I cut the female end off a pair of balanced mic cables and will solder a rca on it.
would you attach outer shield or just hot and cold(+,-) to rca.
the rca is a new Neutric pro series.
thanks John
  • The Demo is Everything!
    • http://www.bryston.com
Re: DIY- RCA to male BALANCED
« Reply #1 on: 28 Dec 2008, 10:22 pm »
thanks John
Only 2 wires not 3.
james
mclsound
« Reply #2 on: 28 Dec 2008, 10:31 pm »
hi James,good holidays i hope.
so hot and cold,not outer shield,correct(this is what is confusing me)
John
« Reply #3 on: 28 Dec 2008, 11:07 pm »
Depending if it is feeding a male or a female it is hooked up differently - I would contact Mike at Bryston for clarity.
james
brucek
« Reply #4 on: 29 Dec 2008, 12:28 am »
Correct, the positive (+) of the RCA connects to the Pin 2 (+) of the XLR, and the ground of the RCA connects to the Pin 3 (-) of the XLR, and the shield of the XLR remains connected at the XLR end only and does not connect to the RCA.
This removes the physical connection between the RCA device chassis and the balanced chassis, which reduces the ground loop considerably. There is still noise rejection realized from this pseudo balanced configuration, since noise rejection basically relies on matched impedances at the two inputs of the differencial amplifier stage. The impedance of the positive differential amplifier will be that of the previous stages output impedance, while the negative differential amplifier will be at ground or zero impedance. The mismatch still offers decent noise rejection.
brucek
mclsound
« Reply #5 on: 29 Dec 2008, 09:01 pm »
thanks all
john
