0 Members and 1 Guest are viewing this topic. Read 211173 times.
Quote from: toobluvr on 5 Apr 2009, 12:39 amNicely done, Roy! How did you get so much butcher block so cheaply?I'll echo that - very nice. I was looking at threaded rod, too. How did you get it and the fasteners so cheaply? What diameter rod did you use?Martin
Martin,I think that adding pieces length, width..., in other words add perimeter pieces top and bottom shelves only would help the twisting problem. Maybe bolt one or two of the Maple shelves to the frame for torsional stiffness. You're right, the diagonal pieces are mostly for side to side stability.-Roy
