Lets talk Attenuators/pre amps
0 Members and 1 Guest are viewing this topic. Read 4621 times.
MerlinWerks
Re: Lets talk Attenuators/pre amps
« Reply #20 on: 8 Jan 2009, 04:02 pm »
You could try a Shunt Mode attenuator, only one high quality resistor in the signal path!
Occam
« Reply #21 on: 8 Jan 2009, 04:29 pm »
As its a voltage divider, whatever isn't shunted down to ground, goes to the divider's output, wouldn't you consider the that shunt resistor(s) in the signal path? I'm not asserting its as important as the series resistor, but does the shunt have a significant impact?
Paul
JoshK
« Reply #22 on: 8 Jan 2009, 04:37 pm »
The way I look at it, the shunt resistor is in parrallel with the load, so it divides the AC current loop.  In other words, it is in the signal path.
Mike B.
« Reply #23 on: 8 Jan 2009, 07:20 pm »
MerlinWerks
« Reply #24 on: 10 Jan 2009, 01:20 am »
Quote from: JoshK
Of course you both are right wrt the shunt being in the signal path, it became clear to me after redrawing it  :oops:
I guess if you built the actual S5 attenuator you would only have two resistors in the path  :green:
